Old 04-16-2019, 04:00 AM   #1
HeavyHauler
Best choice for wheel lug pattern 5x4.75 or 5x5
Which wheel lug pattern would be a better choice for a more variety of custom wheels? Would it be 5x4.75 or 5x5.
I am planning on converting my truck from 6 lug to a 5 lug brake system.
HeavyHauler is offline   Reply With Quote
Old 04-16-2019, 06:45 AM   #2
Re: Best choice for wheel lug pattern 5x4.75 or 5x5
I wouldn't create a freak bolt pattern over custom wheel choice. I'd make the wheels fit the truck not the truck fit the wheels. Plenty of choices in custom wheels, you only need to pick one. I'd stay 6-lug before I'd ever go to the car bolt pattern. Heck, even the most popular car wheels (rallyes) are made in 5 on 5
Old 04-16-2019, 08:15 AM   #3
Mike C
Mike C's Avatar
I’m with Tim on this. Converting to the small car (big car, ie Caprice, Impala used same bolt pattern as the trucks) makes zero sense. And for me, staying 6 lug made zero sense as the wheel choice is just too limited in building a “hot rod” type truck.
Convert to 5 lug discs, use truck 5x5 pattern. Be done.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-16-2019, 08:47 AM   #4
68Stepbed
68Stepbed's Avatar
For the most part, I agree with the two comments above, but let me ask another question. What's your intended purpose for the truck?
As for answering your original question, the 5x5 bolt pattern has become more popular in the past few years. For two reasons, 1- new Jeeps use the same lug pattern. 2- C10 trucks have hit an all time high in popularity, so the market is catering to them. This means that wheel choices are plentiful for these trucks, although still not as many options as the 5x4.75 pattern.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-16-2019, 09:19 PM   #5
jmking9
jmking9's Avatar
I agree that 5x5 would probably be the best choice. But if you have another hot rod or two that you would like to swap wheels around from time to time that are 5x4.75, than I would go with that. Just a thought
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 04-17-2019, 05:57 AM   #6
OARNGESI
OARNGESI's Avatar
Also remember even if you have a 5x4.75 lugs it doesn’t mean all these wheels will have the right bore size or back space since they were designed around a car
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-17-2019, 07:18 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
4.75 is a more common custom wheel pattern.
KQQL IT is online now   Reply With Quote
Old 04-18-2019, 03:40 PM   #8
rjs53
I debated on 5-4.75. Went with 5 on 5 because there is just as many options for wheel selection. Back spacing is gonna be deciding factor when you find a wheel. And also what rear end do you have early or late? Ones wider than the other.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
