Old 04-24-2019, 08:33 AM   #1
jdl71
jdl71's Avatar
Re: 66 k20
Originally Posted by raylube View Post
How's the rear axle coming along?
I bought a 4:10 ho72 last weekend and I’m going to pick up another later this week don’t know what ratio yet. Haven’t done any more.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 04-25-2019, 12:27 PM   #2
Short 3/4
Re: 66 k20
I think your going to like that 4:10 rear, it's a great ratio for these trucks. You can still pull, but allows you to cruse at 60. Should be no problem finding a matching r&p for the front Dana 44 (new or used), much more common than for the HO rears.
While your tearing into that rear, now is a great time to weld in a pipe bung for a drain plug. That's the one thing they are missing, and with clean oil they truly last forever.
I'm putting my money on your noise being in the transfer case. Even after a total rebuild of mine, truck still sounds like it has a bad ring and pinion about to blow. As I said in an earlier post I ran the truck with Xfer bypassed during rebuild, so I know exactly where the noise is coming from. Looks like my next project is some serious sound proofing.
Keep up the good work on the project,
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 04-25-2019, 06:36 PM   #3
jdl71
jdl71's Avatar
Re: 66 k20
Tom
Your statement about the xfer case is in the back of mind every time I fool with it lol. I'm stubborn though and I won't let it go until I've swapped 3rd members and at least drove it once to confirm. Plus the one that's in it has a ton of lash.
I looked at Randys at a r&p set for the front, it wasn't too bad but they said I would likely need a new yoke as the old ones were coarse splined. I'm going to pick up this other center section this weekend and see what ratio it is then make my decision.
I've also been thinking about dynamat or some sort of home depot knock off, and just ignoring the noise until something blows up. I called a local trans shop that I know does t-case rebuilds to see if they had ever worked on one of these, when they mentioned TorqueKing as a parts source I had a feeling they could handle it. Looks like a monster to get out of there though.
Thanks again for all your advice, I really do appreciate it. Been waiting and hoping you'd chime in shortly.
Psalm 23
64 C10
66 K20
Old 04-25-2019, 06:54 PM   #4
jdl71
jdl71's Avatar
Re: 66 k20
I like these nmo antennas, they flex easily and don’t look obnoxious. I don’t know if this is ideal mounting spot (I know the middle of the cab would be best) but I’m going to try it a while.
Psalm 23
64 C10
66 K20
Old 04-25-2019, 09:31 PM   #5
raylube
raylube's Avatar
Re: 66 k20
I hope your rear gears fix your problem. The xfer case is easy to drop out. The upper rear input shaft bearing will come out easy with out pulling case out at least it did on mine. I would look at the shop manual and see if you can fix it yourself it not too complicated. It'll save you money as all parts alone at least 500. And if you need input shaft its near unobtanium.
raylube is offline   Reply With Quote
Old 04-25-2019, 09:44 PM   #6
jdl71
jdl71's Avatar
Re: 66 k20
I’ve wondered how much I could do without pulling it. It doesn’t look complicated to get out but heavy and I don’t have a tranny jack or any help to speak of. I know it needs seals for sure. I’m going to look through the manual again. Thanks, you’ve given me some encouragement to try.
Psalm 23
64 C10
66 K20
Old 05-03-2019, 02:37 PM   #7
straight6chevyguy
straight6chevyguy's Avatar
Re: 66 k20
Since it looks like the antenna sticks up above the cab it should work ok but you really wont know until you try it.
Sometimes short antennas that are shorter than the height of the cab tend to have some of the signal blocked or sometimes wont tune correctly because of funny signal reflections from the metal truck cab being right next to the antenna.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 04-25-2019, 11:33 PM   #8
j.kirn
Re: 66 k20
never heard of a 4.10 gear ratio in a HO72, I have seen them in a HO52
j.kirn is offline   Reply With Quote
Old 04-26-2019, 08:46 PM   #9
jdl71
jdl71's Avatar
Re: 66 k20
It was in a 70 3/4 ton 4x4. Has the adjuster bolt on the yoke which I thought only the ho72 had. 41 10 stamped on the ring gear. Guess someone could have regeared it but the front axle was 4:10 also
Psalm 23
64 C10
66 K20
Old 04-28-2019, 11:25 PM   #10
j.kirn
Re: 66 k20
A H052 is a 3/4 ton , a HO72 is a 1 ton axle
Old 04-29-2019, 01:38 PM   #11
jdl71
jdl71's Avatar
Re: 66 k20
Was there an HO52 with the load bolt?
Psalm 23
64 C10
66 K20
Old 04-30-2019, 11:28 PM   #12
j.kirn
Re: 66 k20
yes
Old 05-02-2019, 08:32 PM   #13
jdl71
jdl71's Avatar
Re: 66 k20
yes
I stand corrected then. I was under the impression only the 72 has that.
Psalm 23
64 C10
66 K20
