Old 04-06-2019, 06:00 PM   #126
jdl71
jdl71's Avatar
Re: 66 k20
Pulled this signal stat 105 out of my parts cab. Yes, I drilled a hole in the dash. I do have the bracket for it but didn’t feel like fighting the hardware holding it in the old cab. Tried using the choke hole first but there just isn’t quite enough room, and I’m pretty sure I’ve seen them like this before. “Period correct”. Lol
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 04-06-2019, 06:03 PM   #127
jdl71
jdl71's Avatar
Re: 66 k20
Dug this light out of my junk box also.
Psalm 23
64 C10
66 K20
Old 04-06-2019, 11:47 PM   #128
raylube
raylube's Avatar
Re: 66 k20
What did you find out with the play in the eaton?
raylube is offline   Reply With Quote
Old 04-07-2019, 08:34 AM   #129
jdl71
jdl71's Avatar
Re: 66 k20
It’s the spiders and/or side gears. Looking for some.
Psalm 23
64 C10
66 K20
Old 04-07-2019, 10:25 AM   #130
350TacoZilla
Re: 66 k20
Truck looked good at the show man! Reminds me of an old pulling truck with the stance and the 15's on there lol.
350TacoZilla is offline   Reply With Quote
Old 04-07-2019, 10:28 AM   #131
jdl71
jdl71's Avatar
Re: 66 k20
Thanks! One of my buddies there said the same exact thing about the pulling truck look. Lol
Psalm 23
64 C10
66 K20
Old 04-07-2019, 09:08 PM   #132
straight6chevyguy
straight6chevyguy's Avatar
Re: 66 k20
Thumbs up on the good work thus far!
That bumper looks good to!
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 chevy c20 350 4speed
1998 chevy c1500 4.3L 5speed
2002 Chevy s10 4.3L auto 4x4
Plus a Mercury & some Fords... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 04-09-2019, 12:28 AM   #133
raylube
raylube's Avatar
Re: 66 k20
Awesome work and cool to see you enjoying it with fellow gearheads. Did you find the source of the noise?
Old 04-09-2019, 08:53 AM   #134
jdl71
jdl71's Avatar
Re: 66 k20
I’m thinking a lot of it is the rear end. I’m going to pull the driveshaft and run it in front wheel drive and and see what happens.
Psalm 23
64 C10
66 K20
Old 04-23-2019, 04:12 PM   #135
jdl71
jdl71's Avatar
Re: 66 k20
A few more minor things got done over the extended weekend. Put in a radio and antenna I had laying around. As well as a close to period cb. Also put these 1 ton emblems on. I know they’re the wrong year and it’s not a K30 but I still like them and will make people ask questions.
Psalm 23
64 C10
66 K20
Old 04-23-2019, 04:15 PM   #136
Clyde65
Clyde65's Avatar
Re: 66 k20
You realize, you have 65 emblems on your truck?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-23-2019, 05:13 PM   #137
jdl71
jdl71's Avatar
Re: 66 k20
Yes, I mentioned that in my post. They’re what I had.
Psalm 23
64 C10
66 K20
Old 04-23-2019, 07:22 PM   #138
Clyde65
Clyde65's Avatar
Re: 66 k20
Ah! Sorry I missed that.
Clyde65
Rebuild of Clyde
support our troops!
Old 04-23-2019, 07:32 PM   #139
jdl71
jdl71's Avatar
Re: 66 k20
No problem.
Psalm 23
64 C10
66 K20
Old 04-23-2019, 11:42 PM   #140
straight6chevyguy
Re: 66 k20
Does the cb work or is it just for looks?
Old 04-23-2019, 11:42 PM   #141
raylube
raylube's Avatar
Re: 66 k20
How's the rear axle coming along?
Old 04-24-2019, 08:31 AM   #142
jdl71
jdl71's Avatar
Re: 66 k20
It works. I’m trying to decide what antenna to use and where to put it. I’ve got a 9’ whip but not sure if I want to go that retro lol
Psalm 23
64 C10
66 K20
Old 04-24-2019, 08:33 AM   #143
jdl71
jdl71's Avatar
Re: 66 k20
I bought a 4:10 ho72 last weekend and I’m going to pick up another later this week don’t know what ratio yet. Haven’t done any more.
Psalm 23
64 C10
66 K20
Old 04-25-2019, 12:27 PM   #144
Short 3/4
Re: 66 k20
I think your going to like that 4:10 rear, it's a great ratio for these trucks. You can still pull, but allows you to cruse at 60. Should be no problem finding a matching r&p for the front Dana 44 (new or used), much more common than for the HO rears.
While your tearing into that rear, now is a great time to weld in a pipe bung for a drain plug. That's the one thing they are missing, and with clean oil they truly last forever.
I'm putting my money on your noise being in the transfer case. Even after a total rebuild of mine, truck still sounds like it has a bad ring and pinion about to blow. As I said in an earlier post I ran the truck with Xfer bypassed during rebuild, so I know exactly where the noise is coming from. Looks like my next project is some serious sound proofing.
Keep up the good work on the project,
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 04-25-2019, 12:36 PM   #145
Short 3/4
Re: 66 k20
I put '20' badges on mine for the same reason. Mine is a short bed that I put period correct 3/4 ton axles on, so makes a lot of people scratch their heads, and starts a lot of conversations
292-SM420-T221
Old 04-25-2019, 06:36 PM   #146
jdl71
jdl71's Avatar
Re: 66 k20
Tom
Your statement about the xfer case is in the back of mind every time I fool with it lol. I'm stubborn though and I won't let it go until I've swapped 3rd members and at least drove it once to confirm. Plus the one that's in it has a ton of lash.
I looked at Randys at a r&p set for the front, it wasn't too bad but they said I would likely need a new yoke as the old ones were coarse splined. I'm going to pick up this other center section this weekend and see what ratio it is then make my decision.
I've also been thinking about dynamat or some sort of home depot knock off, and just ignoring the noise until something blows up. I called a local trans shop that I know does t-case rebuilds to see if they had ever worked on one of these, when they mentioned TorqueKing as a parts source I had a feeling they could handle it. Looks like a monster to get out of there though.
Thanks again for all your advice, I really do appreciate it. Been waiting and hoping you'd chime in shortly.
Psalm 23
64 C10
66 K20
Old 04-25-2019, 06:54 PM   #147
jdl71
jdl71's Avatar
Re: 66 k20
I like these nmo antennas, they flex easily and don’t look obnoxious. I don’t know if this is ideal mounting spot (I know the middle of the cab would be best) but I’m going to try it a while.
Psalm 23
64 C10
66 K20
Old 04-25-2019, 08:50 PM   #148
jdl71
jdl71's Avatar
Re: 66 k20
Ordered a fender from rockauto the other day. The old one was beyond saving so I didn’t feel too bad about hacking it up to get it off. The new one is just hanging on there for tonight, it will need a lot of tweaking.
Psalm 23
64 C10
66 K20
Old 04-25-2019, 09:31 PM   #149
raylube
raylube's Avatar
Re: 66 k20
I hope your rear gears fix your problem. The xfer case is easy to drop out. The upper rear input shaft bearing will come out easy with out pulling case out at least it did on mine. I would look at the shop manual and see if you can fix it yourself it not too complicated. It'll save you money as all parts alone at least 500. And if you need input shaft its near unobtanium.
Old 04-25-2019, 09:44 PM   #150
jdl71
jdl71's Avatar
Re: 66 k20
I’ve wondered how much I could do without pulling it. It doesn’t look complicated to get out but heavy and I don’t have a tranny jack or any help to speak of. I know it needs seals for sure. I’m going to look through the manual again. Thanks, you’ve given me some encouragement to try.
Psalm 23
64 C10
66 K20
