Old 05-16-2019, 12:23 PM   #1
profe56
Sbc starter
Hi folks good morning.
I just rebuilt an engine, I think I”ll need a new street performance starter. Do you have suggestions?
profe56 is offline   Reply With Quote
Old 05-16-2019, 12:35 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Sbc starter
Have 3 of these on my fleet.
ACDelco 337-1011 Professional Starter https://www.amazon.com/dp/B007QBSX5A..._Yez3Cb50N41WQ
Old 05-16-2019, 12:55 PM   #3
profe56
Question Re: Sbc starter
Thank you KQQL.
I think I could find it at NAPA local stores.
Old 05-16-2019, 12:58 PM   #4
profe56
Re: Sbc starter
If not, I”ll order from amazon
Old 05-16-2019, 01:29 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Sbc starter
Friend at the starter rebuilder in town says he cant buy them for the Amazon price.
Old 05-16-2019, 01:45 PM   #6
RodnRudy
RodnRudy's Avatar
Re: Sbc starter
I used one of these on my 350. works great
https://www.dbelectrical.com/product...sdr0031-l.html
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 05-16-2019, 05:51 PM   #7
profe56
Re: Sbc starter
The engine is SBC w/700 trans and the year of the engine is probably 73/76
Old 05-16-2019, 06:16 PM   #8
profe56
Re: Sbc starter
Thanks guys!!!
I just ordered
Old 05-16-2019, 06:21 PM   #9
my56chevytruck
my56chevytruck's Avatar
Re: Sbc starter
A Tilton mini starter is a great item
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 05-16-2019, 11:24 PM   #10
dmjlambert
dmjlambert's Avatar
Re: Sbc starter
ACDelco .... Professional Starter ...
For the ACDelco mini starters like that, what is the correct thing to do regarding bolting it to the engine? I had a mini starter once for a couple of months, and had the wrong bolts, didn't know what bolts to get, couldn't not figure out the shimming, and ended up chewing up my flex plate, replaced the flex plate and put the original big starter back in with its original bolts. I understand there are supposed to be special bolts to use with an unthreaded portion that goes into the block. So, I'm interested in knowing the exact right thing to do, for example, part numbers on bolts, do we use washers or lock washers, thread locker, or what all is needed?
Old 05-17-2019, 12:29 AM   #11
BCOWANWHEELS
Re: Sbc starter
Get a vette hi-torque 1969-1970 lt-1 reman, trade your old one in for core. Stay away from them gear reduction / china junk
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 05-17-2019, 12:38 AM   #12
franken
Re: Sbc starter
Heh, I tend to agree w/ post 11 and would suggest that people learn the tiniest bit of electrical theory, then fix the messed up wiring in the vehicle.
Old 05-17-2019, 10:05 AM   #13
profe56
Re: Sbc starter
Thanks: I ordered this one from amazon, just in case the bolts are not included I will have for new ones.
Old 05-17-2019, 12:35 PM   #14
BCOWANWHEELS
Re: Sbc starter
that's not hi-torque
Old 05-17-2019, 01:30 PM   #15
profe56
Re: Sbc starter
Ok
Cancelled!!
Old 05-17-2019, 02:51 PM   #16
BCOWANWHEELS
Re: Sbc starter
want me to get you a part number
Old 05-17-2019, 03:51 PM   #17
profe56
Re: Sbc starter
Yes thank you
Old 05-17-2019, 04:08 PM   #18
BCOWANWHEELS
Re: Sbc starter
I just bought 1 from advance auto. $81.99 / ac delco number 3962253. 1970 corvette hp
Old 05-18-2019, 08:48 AM   #19
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Sbc starter
I linked the wrong p-n
337-1022 ac delco $100 usually from Amazon.
678-107 Dorman x2
Gear reduction will outperform a direct drive at half the amp load.
