Old 05-29-2019, 11:40 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Re: I need steering column help
Originally Posted by Phoax View Post
I figured I should mention I added power steering to the truck so the small diameter steering wheel is no problem. No power steering in 67'. The motor in the truck is a used 350 crate engine I found on craigslist that came with a power steering pump. All of the engine accessories are on one giant bracket. I found it easier and less expensive to add a power steering gear than to subtract the the pump from the engine. I picked one up for $60 at the local junkyard. It didn't just drop in but I figured it out with a cutting torch.
Glad to see you got it all dialed in. I have a small wheel on my '72 C30 and I like it.
LockDoc
Leon
