Crossmember
To get a 5.3L and 4L60e to fit, does the crossmember have to come out?
1971 c10 with 250 cid and manual transmission Posted via Mobile Device |
![]() ![]() Join Date: May 2015
Re: Crossmember
I would pull it if nothing more than to just it out of the way...it wont be needed...
60-66 Nut
Re: Crossmember
Yes remove the bellhousing crossmember. It is not needed for an auto trans and it will just be in the way.
Re: Crossmember
Thanks.
Re: Crossmember
nice, this was one of my questions as well. I get to break out the air hammer again
Re: Crossmember
You will need to support the rear of your 4L60E, do you have a xmember for the trans mount
Re: Crossmember
I have a crossmember for the auto tranny.
I had to remove the manual tranny crossmember like y’all suggested. I also had to disconnect the e brake cable while maneuvering engine and transmission in. Posted via Mobile Device |
