Old 06-08-2004, 10:06 AM   #1
53burb
53burb's Avatar
fuel pump
I have a see-thru plastic fuel filter (Fram#G2) on my 350. On my previous truck, I had the same filter. In the filter, I could see it was usually about 1/4 to 1/2 full. The filter was mounted horizontally. This filter is mounted horizontally as well. However, the filter does not seem to have fuel in it. This hasn't caused any problems with it running. Is my fuel pump on the way out?? The PO says it was replaced less than 4 years ago...
53burb is offline   Reply With Quote
Old 06-08-2004, 08:53 PM   #2
Sublvr72
Sublvr72's Avatar
I have the same clear plastic fuel filter, and mine is also always 1/4 to 1/2 full. I have changed fuel pumps numerous times and it always remains at the same level.
here is the filter
Sublvr72 is offline   Reply With Quote
Old 06-08-2004, 09:14 PM   #3
1972C10
1972C10's Avatar
Mine used to stay half full Then i got an electric pump now it stays plum full its vertical thou but i dont think that matters too much
1972C10 is offline   Reply With Quote
Old 06-09-2004, 10:21 AM   #4
53burb
53burb's Avatar
I also forgot to mention that when the engine is hot, it does not start right away. Could the pump be weak and beginning to show signs of not being able to overcome vapor lock.
Old 06-09-2004, 10:33 AM   #5
JimKshortstep4x4
Smile
I doubt if you have vapor lock. It is not unusal for the filter to look empty.
You will still have fuel in the carb when it is hot unless you have a problem with your carb. I would suspect the carb is causing you hot start problems.
Jim
Old 06-09-2004, 10:54 AM   #6
53burb
53burb's Avatar
I forgot that the fuel bowls in the carb would have gas. The carb is a new Edelbrock Performer 650 CFM. Do have any suggestions as to what would need to be adjusted??The idle mixture seems to be ok, but maybe it is not??
Old 06-09-2004, 12:07 PM   #7
53burb
53burb's Avatar
I spoke with an Edelbrock Rep. He said I needed Gasket Part#9266 underneath the carb. He sounded pretty confident that the gas was getting too hot & this was the problem. Does this sound correct??
Old 06-11-2004, 08:58 AM   #8
TexSparks
Hot starts
Try adjusting your timing a little before you start making too many carb changes.
'72 4x4 Blazer (in the works)
TexSparks is offline   Reply With Quote
Old 06-14-2004, 10:06 AM   #9
53burb
53burb's Avatar
I recently installed an HEI distributor & set the timing @ 10 Degrees BTDC. I spoke with a guy this weekend who suggested retorquing the carb bolts after it heats up...
