Old 09-30-2019, 10:30 PM   #1
Klassen kustoms
Rear shock bolt ripped out of frame
What’s my best bet at going about this ? ... I plan on redoing the whole suspension, brakes, everything as I have the truck down to a rolling frame right now. But the previous owner really... badly welded this on here and I got it off ... but I don’t see how I’d put another one in ... is there any good relocations for better shock placement, should I just bite the bullet and do a 4 link?
Klassen kustoms is offline   Reply With Quote
Old 10-01-2019, 07:17 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Rear shock bolt ripped out of frame
I would make a plate to cover up that mess...no big deal to fix that right
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-01-2019, 12:27 PM   #3
SCOTI
SCOTI's Avatar
It all depends on how much effort you want to put into the solution & what your ultimate goals are. The easy fix is another plate on top of the problem area w/a new, same style shock stud. The plate could be welded or bolted in place depending on your skill level or tools on hand.
Relocated upper mounts can be done or the complete suspension change as you mentioned will also put the shocks in a different spot.
More info from you about everything yields better options.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-01-2019, 12:57 PM   #4
Klassen kustoms
Plan is to have. Nice handling Street/strip truck
Decent power goals in mind with lots of money in suspension/brakes
Old 10-01-2019, 01:05 PM   #5
kwmech
If going back with welding I've seen these on Amazon (I think)
Old 10-01-2019, 01:07 PM   #6
Klassen kustoms
Not a bad idea
But I’d have to figure out a way to cut it out and fill it in with a new hole... I’d rather not just put a plate over it cause then it wouldn’t be even with the other side
Old 10-01-2019, 02:09 PM   #7
mongocanfly
simple plate and one of the studs like KW shows will fix it.....doesnt have to match the other side
that small of a thickness difference wont affect anything
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-01-2019, 03:09 PM   #8
Klassen kustoms
Alright maybe I’ll do that then
I assume you put it on the inside of the frame ?
Old 10-01-2019, 05:41 PM   #9
SCOTI
SCOTI's Avatar
The easiest option that aligns best.
Not trying to be an shmuck, but while that's an answer, it's a vague one. Were you planning to swap out the OE stuff for aftermarket options (optimum) or tweak the factory parts to work 'better' (improved OE but still OE limitations)?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-01-2019, 06:06 PM   #10
Klassen kustoms
My bad
I am changing out everything
Most likely tubular a arms, coils, c notch, 9” in the back, etc etc
Old 10-01-2019, 06:54 PM   #11
sweetk30
sweetk30's Avatar
here is a kit that works great to help save before broken frame or help firm up a repair .
these guys have good stuff . http://offroaddesign.com/catalog/RearShockBrace.htm
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-01-2019, 07:41 PM   #12
SCOTI
SCOTI's Avatar
My bad
Gotcha.... Now we're better advised.
Look @ Ride Tech, Hotchkis, & QA1 for suspension upgrades that are bolt-on swaps w/your existing crossmember & steering box up front. No Limit Engineering or Roadster Shop for revised & updated geometry bolt-in suspensions w/revised crossmembers w/R&P steering.
Check them out & share your thoughts. We can help guide your decisions from there.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-01-2019, 07:49 PM   #13
Klassen kustoms
Alright thank you I will check them out and let you guys know
Old 10-02-2019, 06:36 AM   #14
74CustomK20
74CustomK20's Avatar
With lots of money in suspension and brakes, and since you have the truck down to a rolling frame, sound like ya answered your own question.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
