Old 10-01-2019, 10:20 PM   #1
Factory Guy
Factory Guy's Avatar
1973-1979 Tachometer?
I am wanting to install the factory style tach in the fuel gauge location and place the fuel gauge in the brake lite location has anybody else done this conversion?
Not really wanting to buy the used parts off of ebay or ? I have read to many stories of used or NEW NOS ones not working. So I plan to go with a repop kit like LMC shows in the photo.
Factory Guy is offline   Reply With Quote
Old 10-01-2019, 10:24 PM   #2
Factory Guy
Re: 1973-1979 Tachometer?
***Anybody know what that big white hole is in the tach face at the bottom?***
Old 10-01-2019, 10:26 PM   #3
Factory Guy
As my gauges do not have that hole
Old 10-01-2019, 10:32 PM   #4
dmack91
dmack91's Avatar
Indicator lights. Not sure which ones on your application, but some possibilities are brake, seat belt, 4x4....
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 10-02-2019, 08:47 AM   #5
MJN
MJN's Avatar
Besides the gauges, you will also need a different printed circuit and white plastic housing to accommodate the tach and fuel gauge. The tach also uses a stand alone harness that is not part of the printed circuit. The large window is for indicator lights as was mentioned. The older '73/'74 tachs did not have an indicator light window, the brake light indicator with tach was in the speedometer. The information at this link should help answer some of your questions as the gauges and clusters changed through the years.
http://www.73-87.com/7387garage/inte...achometers.htm
Since you already have gauges it will be a direct plug in to your cab harness with the correct printed cluster circuit.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 10-02-2019, 11:42 AM   #6
Dead Parrot
I bought the same gauges for a cluster I pulled from an 89 Suburban with the idea of putting it in my 75. Plan got put on hold due to buying 80 acres and moving. The 89 cluster had a red plate for Brakes and Seat Belts behind the gas gauge. Was thinking of re-purposing the Seat Belt side into a Hot or Oil idiot light backup to the gauges. There are enough cluster pins to have both gauges and some idiot lights and IIRC, the 89 Suburban had 4-wheel drive so every possible light socket had a circuit trace to it. I think the pair behind the speedo was 4-wheel drive and Check Engine.
Dead Parrot is offline   Reply With Quote
Old 10-02-2019, 10:07 PM   #7
Factory Guy
Thanks everybody for your help I really appreciate it.
Old 10-02-2019, 10:40 PM   #8
dagnabbitt
dagnabbitt's Avatar
Good luck with the tach swap, a factory gauge is really nice to have and you will love it. Beware, as soon as I did mine I got to thinking I needed to reduce my rpms and started a 700r4 rebuild. Everything you do leads to more money but its a great hobby and totally worth whatever time you put into it.
Post pics of your progress, this is something everyone wants to do eventually and this site is a great resource that you can be a part of.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
dagnabbitt is online now   Reply With Quote
Old 10-02-2019, 10:58 PM   #9
Factory Guy
Thanks for the words of encouragement. Truck has 4.11 gears so thats why I want the tach to see how high she is revving. don't know if I will go for an over drive trans or a GEAR VENDORS overdrive.
I have a thread of the truck and what I have done to her so far at:
http://67-72chevytrucks.com/vboard/s...d.php?t=791250
