![]() Join Date: Mar 2006
Re: Wheel Size for Disc Conversion
You are on the right track with the Wheel Vintique style 62's. As long as you are using the standard disc brakes and not a "big" brake kit, 15" wheels are large enough. For RPM / tire diameter, do a search for "RPM Calculators" that will let you input your axle ratio, tire size and transmission to find rpm's at different speeds.
| Bookmarks |
