Old 12-14-2019, 07:10 PM   #7
ray_mcavoy
Re: Too far gone. Jimmy
Originally Posted by hatzie View Post
The door cards have to come off. You might break the pins off or you might not. If you take care you can remove them but they are mounted through the door card.
Yes, removing them without breaking off the plastic stud pins (which are molded as part of the trim) can be tricky. Simply trying to unscrew the speed nuts will usually result in twisting off the pins. Using pliers to grip the protruding end of the pin to prevent it from twisting while using a wrench to remove the nuts will decrease the chance of breaking them.
ray_mcavoy is offline   Reply With Quote
