Old member
Is this the right nut for 67-72 door panel screw's. The ones in the lower part of the door for the metal panel.
1/4"-20 ![]() https://www.grainger.com/product/487...g!109231851957!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
The Older Generation
Re: Question???
That is the correct thread but the retaining clips look like they stick out farther. Don't know if that will interfere with the panel fitting up against the door or not. LockDoc
Re: Question???
IIRC, those are correct. My door panels are the metal style and I have replaced a few of these over the years
#4 | |
Old member
#5 | ||
"I ain't nobody, dork."
Re: Question???
You ain't ordered those yet?
![]() Gary
![]() Join Date: Apr 2016
Re: Question???
The nuts on my doors are a different kind, they are square nuts with tabs and appear to be permanently attached in some way into the square holes in the door, I don't know if pressed or welded. I had one that was rusted and broke loose, so I replace it with one of those cage nuts you show above, that I got at Ace Hardware. It works fine.
Last edited by dmjlambert; 12-15-2019 at 11:52 PM. Reason: changed word wings to tabs, it is a better description |
#7 | |
Old member
| Bookmarks |
