Old 01-18-2020, 09:20 PM   #1
Simple10
Simple10's Avatar
Re: Ignition removal?
Originally Posted by Andy4639 View Post
Yes! You don't have to remove anything to take the connector off the back. Just take a small screw driver and pry the 2 prongs out of the holes.
Something is loose on the back of mine ...does the front bezel tighten it up or the piece on the back?must be a bad connection somewhere sometimes it won’t start unless I wriggle the back of it around.
Simple10 is offline   Reply With Quote
Old 01-18-2020, 10:20 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Ignition removal?
You can twist the barrel like Doc stated in the link but it want come completely apart unless the cylinder is removed. You need to take the plastic wire connector off and twist it back together then take the cylinder out like you want to begin with then twist it off.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-18-2020, 11:21 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
You need a new ignition switch if you have to wiggle the key around. All the rest is just mechanical mounting hardware. The contacts inside the switch carry quite a bit of current, especially on the start circuit. If you can find it there in OZ, go ahead and replace the lock cylinder while you're at it. Having different keys for the door and ignition prevents people from using a slide hammer to remove a door lock cylinder and quickly duping a key and then driving your prize away. It's really just a delaying tactic, because if someone really wants your truck, they're going to get it. It is possible that the plug is the problem, but you can inspect that once you pop it off.
~Steven
Simi Valley, CA
