Old 01-20-2020, 06:46 PM   #11
LS short box
Re: Hooker Blackheart 1967-72 C10 Truck LS/LT Swap System Info Thread
Toddoky,
Can I ask why you kept your oil pan 1.5 inches off the front cross member? The reason I ask this question because when I was running a T56 magnum to keep the engine angle to a minimum I had to trim the upper trailing cross member pass thru hole to clear the drive shaft.
Seems to me the engine could be lower maybe an inch? I am running 6" drop in the back. On my 68 C10 LS I'm running a F-body oil pan. With just using my calibrated eye ball (and a tape measure) the drag link is a bit higher than the top of the cross member.
Not saying your engineers haven't done their home work just asking.
