02-03-2020, 10:40 AM | #1 |
Still Green but learning
Manual Fuel pump install 67-72 C10
PSA for any other amateurs stumbling on this in a google search... When youtube and the rest of the interweb say lift the pin, what they really mean is PUSH the pin up into the block.
That is all....
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
02-03-2020, 11:21 AM | #2 |
Re: Manual Fuel pump install 67-72 C10
Yes, and almost nobody mentions the short bolt in the front of the engine that lines up with the push rod. I remove it and put in a longer bolt that can snug up against the rod to hold the rod in the up position. Then, when done installing the fuel pump remove the longer bolt and re-install the short bolt. Shown here by forum member Longhorn Man in this thread:
02-03-2020, 11:35 AM | #3 | |
remember to put RTV on the short bolt when you put it back on to prevent oil leaks.
02-03-2020, 11:47 AM | #4 |
20' Daredevil (Ret)
I spent a lot of time frustrated while trying to install a fuel pump before I learned about that bolt here on this board. Sure makes the job easier!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
