Old 02-06-2020, 09:43 PM   #1
NewBayColony
NewBayColony's Avatar
72 292 Harmonic Balancer Advice
Try to buy a harmonic balancer for my 1972 292. I can find them for 73 and up. Does anybody know the difference? Thanks.
72 C20 292 3OTT
77 GMC 2500 4x4 Longstepper 350 4sp
50 3100 ex Airforce/Town of Mendon fire truck
72 GMC 1500 2wd short stepside 250 4sp
78 GMC 2500 4x Longstepper 292 4sp
54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman)
NewBayColony is offline   Reply With Quote
Old 02-07-2020, 01:08 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 72 292 Harmonic Balancer Advice
The proper 3-groove HB for the L-25 292 L6 is GM p/n:10141202.
No clue on current availability. You may have to file the contacts on your Flux Capacitor to find one.
Old 02-07-2020, 09:11 AM   #3
chc1955
This is where I bought a replacement for mine.
https://www.damperdoctor.com/ he is pretty quick to send it out and a really cool guy. I have my old one that I never sent back for my core deposit. I will post pics tonight.
chc1955 is offline   Reply With Quote
Old 02-07-2020, 11:07 AM   #4
Wrenchbender Ret
The older one had wider belt grooves as they used the old wide belts. I fyou wated to change to the nerrow belts you would need different pulleys, water pump & therm. housing. & alt mounting bracket.
Wrenchbender Ret is offline   Reply With Quote
Old 02-07-2020, 05:24 PM   #5
NewBayColony
Thanks for the replies.
By the way, Mr. Sunshine, my Mr. Fusion is on the blink.
72 C20 292 3OTT
Old 02-07-2020, 09:58 PM   #6
Grumpy old man
Grumpy old man's Avatar
Summit .
https://www.ebay.com/itm/PowerBond-P...rd!37938!US!-1
Old 02-07-2020, 11:14 PM   #7
'68OrangeSunshine
Originally Posted by Grumpy old man View Post
Why does the EBay compatability calculator say this part is not compatible with 68 Chevy C/10 w/292? Dumb calculator, I guess. Parts picture looks good. Fair price.
Old 02-07-2020, 11:21 PM   #8
'68OrangeSunshine
Thumbs up Re: 72 292 Harmonic Balancer Advice
I could've killed my machinist when he tossed my OEM 3-groove pulley in the trash. He said it was junk. Maybe it was cracked. I wanted to send it in to the Damper Doctor. I wound up with a 2-groove HB, he said was made in Australia.
Old Man Emu?
Old 02-08-2020, 08:47 AM   #9
NewBayColony
That is the one I found but it says it fits from 73 and up. It sure looks like mine. I'm going to the shop where I'm working on it today to measure the one on my engine. If it's different, I'll send mine to the Damper Doctor. I didn't want to do that because I'm using a friends shop and didn't want to tie up a bay for any extra time needed to ship mine to CA and back. Thanks for the help.
72 C20 292 3OTT
Old 02-08-2020, 08:51 AM   #10
NewBayColony
Some of these calculators are weird. I was trying to buy a LUK 11" clutch for my72 C20 pickup and the calculator said it would't fit but it will fit a 72 C20 Suburban. I don't know if something is different or not but that doesn't seem right.
72 C20 292 3OTT
Old 02-08-2020, 03:24 PM   #11
'68OrangeSunshine
Maybe it was programmed to know that all '72s have a 12'' clutch. IDK, really.
Everyone knows Suburbans are so much smaller. [!?]
