#26 |
Re: C20 8lug to C10 5lug!
Yep, They're shuttering ECE.
But, changing an 8-lug suspension to 5-lug can still be done just like it was before ECE had the conversion spindles.
#27 | |
![]() Join Date: Jun 2019
Did you swap the C10 leaf springs in the rear as well? I am wanting to do this to mine since I am tired of the stiff ride and will NEVER carry any heay loads again! |
#28 | |
Since the frame itself is different/heavier duty, there might be some height variation to prepare for since your truck is currently stock height. Guys like 'KQQL IT' don't have to worry about it since they were dropping/lowering their builds.
#29 |
#30 |
The only thing that's impacted for this conversion by ECE closing their doors is the marketed 3/4 to 1/2 ton conversion spindle. You can still just use 1/2 spindles w/the correct 1/2 ton required parts. The conversion spindle just made it easier to do...
#31 | |
From all the reading I have been doing what I came up with is that I can switch from 8 to 5 lug by changing the spindle. In order to do that I need to change the upper and lower ball joints. The upper arm will accept the smaller C10 ball joint but the lower arm would need to be replaced cause the hole is to big for the C10 ball joint. Sound about right? |
#32 | |
| Bookmarks |
