Old 04-07-2020, 03:31 PM   #1
Reno
Reno's Avatar
Tilt Column
How do I identify year of a tilt column. This came in my 1970 blazer but has ignition on column so I’m sure it’s not 67-72. It is an automatic on column - must of came from a salvage yard as it has 4 speed automatic written in yellow marker on column. Can’t read the year could be 1988 or 1998?
Thanks in advance
Reno is offline   Reply With Quote
Old 04-07-2020, 04:07 PM   #2
Ziegelsteinfaust
Re: Tilt Column
Going off memory in the years, but they are visually identifiable easily. So easy even Steveie Wonder can do it. Pre 81's have a basic or blank stalk for turn signals, and post 81 have wipers on the stalk like modern cars.
Ziegelsteinfaust is offline   Reply With Quote
Old 04-07-2020, 07:57 PM   #3
Bloodhound
Re: Tilt Column
Wipers weren't on the turn signal stalk until '83.
Bloodhound is offline   Reply With Quote
Old 04-07-2020, 09:43 PM   #4
Pontiac1976
Pontiac1976's Avatar
Re: Tilt Column
84 was the first yr GM for trucks that wipers were on the signal stalk.
The tilt stalk can be a tattle tail to what year and the steering wheel un less they change them, the length wiper stalk size shape. Keys some time give a idea main wire plug/ wire colors get close to the yr.
A few pic of the wheel parts get a few narrow it down.
83 the wiper switch was on the dash.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-08-2020, 07:50 AM   #5
Re: Tilt Column
I have been told the center shaft/spline changed when we got air bags, so I would assume 1994 would be as new as it could be if it has an older style wheel. I am not sure what year the 700R4 was an option.
