Old 03-10-2019, 05:23 PM   #1
Afirehawk1
66 c10 Voltmeter Conversion Final Wiring
Swapped the ammeter with a voltmeter.
One wire should be a 12 volt ignition wire under the dash??
What about the 2nd wire?
Afirehawk1 is offline   Reply With Quote
Old 03-10-2019, 05:25 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 c10 Voltmeter Conversion Final Wiring
We pretty much dont do anything here without pics.
Old 03-10-2019, 05:31 PM   #3
Afirehawk1
Can not get a good photo
Im using the American Autowire Classic set which does not support the ammeter so i converted the ammeter to a voltmeter.
Thinking to the alternator or maybe battery but not sure
Old 03-11-2019, 01:34 AM   #4
Mack B
Mack B's Avatar
If I'm reading you right and you are just installing a voltmeter in place of an ammeter:
I'm 99% positive all you need for a voltmeter is a keyed hot and a ground.
Mack B is offline   Reply With Quote
Old 03-11-2019, 06:56 AM   #5
Afirehawk1
So a 12 volt ignition wire would work?
Old 03-12-2019, 10:28 PM   #6
Cooper197
Cooper197's Avatar
Yes. 12v ignition and the other wire to ground in most cases.
Cooper197 is offline   Reply With Quote
Old 03-13-2019, 02:38 PM   #7
damnyankee36
damnyankee36's Avatar
Tapping into one of the pink wires at the back of the cluster would be the easiest.
damnyankee36 is offline   Reply With Quote
Old 03-13-2019, 03:46 PM   #8
straight6chevyguy
straight6chevyguy's Avatar
Running the positive wire to the accessories terminal on the ignition switch should work
and connecting the negative to any ground (the dash or any grounded part in side the cab) .
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 Chevy c20 350 4speed
1998 Chevy c1500 4.3L 5speed
1999 Chevy k1500 Suburban 5.7L auto 4x4
2002 Chevy s10 4.3L auto 4x4
1971 Mercury Monterey wagon 400 auto
Plus other misc. ... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 03-13-2019, 03:49 PM   #9
straight6chevyguy
All so an accessories terminal on the fuse block would work for the 12 volts.
Old 03-13-2019, 07:43 PM   #10
spudder
Active Member
Like stated above, it's as easy as tapping into a pink wire on the back of the instrument cluster. From the other terminal on the voltmeter, run a wire to a clean ground anywhere close.
The pink wire is 12 volt hot with key on.
I would test the voltmeter on a battery source before installing it to determine which terminal is +.
spudder is offline   Reply With Quote
Old 04-10-2020, 11:40 AM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Have you figured out how to post pictures? It'd be interesting to see how it looks.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
