E Rod LS3 conversions in Cali
Looking for a shop that handles E Rod conversions in California, my 83 Silverado is at it's last days with the 305 and Qjet, barely passed my last smog test. have the finances to have it done professionally and right. all the old mechanics are gone and retired, my local mech that i would take my truck to retired and all the other shops i've gone to won't touch it.
#2 | |
Re: E Rod LS3 conversions in Cali
http://pacificfabrication.com/servic...0b9edb98315bb0
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Thanks.
A guy I am familiar with dropped a 5.3 LS kit he built into his truck in a couple weekends. There were a couple small mistakes with fuel line hook-ups, and he even used a bolt in exhaust. Which when modified took a bit more time. He said afterwards he could do it in a weekend if he quite messing with stuff, and had the right fittings.
Given shop rates. You could probably do it cheaper yourself even if you take a week off of work. Provided your willing to do it. With the Covid going around, and depending on your work situation. You already have the time off. Even if you get the new motor in you could cut down you project cost. |
What trans are you running. I did a eRod in a 89 caprice for a guy not to hard depending on what parts your running.
#6 | |
![]() Join Date: Apr 2018
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
Here in Central Cal just south of Fresno.
Hit these guys up, down in Corona, CA.
https://www.ls-swaps.com/contact Honestly LS swaps are becoming more and more commonplace these days, seems like it shouldn't be impossible to find a good shop to swap for you. Up here in the Bay Area we have Precision Auto services in San Bruno that cranks out LS swaps by the dozen... https://www.facebook.com/PrecisionAutoSanBruno/ Sonoma County street rodz in Petaluma does good work, and has plenty of experience with LS and Erod setups. Pacific fab/Tilden motorsports in Gilroy rebuilds and sells the engines (have one of their built 6.0L's in my 62 Impala.) But not sure they do installs anymore. Worth giving them a call though, they might be able to direct you to a shop closer to you. Maybe once this Corona nonsense calms down start hitting the local cars n coffee meets, car shows and cruises, and ask around. Id guess there's a pretty stout car scene down by Fresno...
![]() Join Date: Jul 2000
Will the CA smog Nazis be looking for all the emissions devices the 84 had, or do they just check tailpipe emissions? Still can't believe some states check emissions on cars and trucks 25 years or older, since they probably account for less than .01% of the vehicles on the road, and even a lower percentage of total miles driven.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
The erod kit comes with its own exhaust y pipe with converters, and the must be used.
All installs are different, but it is the evap emission equipment that must be utilized. How ever you get there is the tricky part. But I have it on good word that make it look good, and they go for it. |
#11 | |
![]() ![]() Join Date: Oct 2014
#12 | |
https://ww3.arb.ca.gov/msprog/afterm...o/d-126-30.pdf |
#13 | |
#14 | |
#15 | |
That's pretty cool. Even meets CA standards. GM sure makes it easy.
#16 |
Be sure that your truck falls under the weight limit.
The LS3-6.2L V8 E-ROD Kit is a complete engine and emission control package designed to change engines from 1995 and older passenger cars and light duty trucks within the maximum weight limit (5725 lbs. GVWR) My 1990 3/4t Suburban is over the rating and they will not allow me to have the LS3 E-Rod engine in my suburban. I am installing it in August and registering the car in Utah. |
#17 | |
Just guessing here, but I suspect the new engine is cleaner than your original 1990 engine.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 04-21-2020 at 11:51 AM. |
#18 |
The erod package is not complete. You still need to tie it into your evaporative emissions your original vehicle has.
#19 |
No the Erod package is complete. You have to tie in the evap canister that is supplied with the engine. The kit comes complete with the cats and evap canister. The only thing is you have to supply the vent line from your gas tank.
#20 | |
:EDIT: Did better googling and found it... https://arb.parts/Executive-Order/D-126-32
#21 |
What is the weight of a half ton short bed Silverado with the 305?
#22 | |
Might be something I'd look into before dropping the $ on an E-rod setup. Or even swing by a smog referee shop and see what they say.
#23 | |
#24 | |
#25 | |
| Bookmarks |
