Old 04-13-2020, 01:04 PM   #1
Loco83
Loco83's Avatar
E Rod LS3 conversions in Cali
Looking for a shop that handles E Rod conversions in California, my 83 Silverado is at it's last days with the 305 and Qjet, barely passed my last smog test. have the finances to have it done professionally and right. all the old mechanics are gone and retired, my local mech that i would take my truck to retired and all the other shops i've gone to won't touch it.
Loco83 is online now   Reply With Quote
Old 04-13-2020, 04:40 PM   #2
Matt Man
Matt Man's Avatar
Re: E Rod LS3 conversions in Cali
Do not know where in California you are, but pacific fabrication would be a great place.
http://pacificfabrication.com/servic...0b9edb98315bb0
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 04-13-2020, 05:10 PM   #3
Loco83
Loco83's Avatar
Thanks.
Old 04-13-2020, 08:11 PM   #4
Ziegelsteinfaust
A guy I am familiar with dropped a 5.3 LS kit he built into his truck in a couple weekends. There were a couple small mistakes with fuel line hook-ups, and he even used a bolt in exhaust. Which when modified took a bit more time. He said afterwards he could do it in a weekend if he quite messing with stuff, and had the right fittings.
Given shop rates. You could probably do it cheaper yourself even if you take a week off of work. Provided your willing to do it.
With the Covid going around, and depending on your work situation. You already have the time off. Even if you get the new motor in you could cut down you project cost.
Ziegelsteinfaust is offline   Reply With Quote
Old 04-14-2020, 11:33 AM   #5
chebyshortbox65
chebyshortbox65's Avatar
What trans are you running. I did a eRod in a 89 caprice for a guy not to hard depending on what parts your running.
chebyshortbox65 is offline   Reply With Quote
Old 04-17-2020, 03:19 AM   #6
ShortHaul
ShortHaul's Avatar
where ya located?
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 04-17-2020, 05:16 PM   #7
Loco83
Loco83's Avatar
Here in Central Cal just south of Fresno.
Old 04-17-2020, 06:59 PM   #8
ShortHaul
ShortHaul's Avatar
Hit these guys up, down in Corona, CA.
https://www.ls-swaps.com/contact
Honestly LS swaps are becoming more and more commonplace these days, seems like it shouldn't be impossible to find a good shop to swap for you.
Up here in the Bay Area we have Precision Auto services in San Bruno that cranks out LS swaps by the dozen...
https://www.facebook.com/PrecisionAutoSanBruno/
Sonoma County street rodz in Petaluma does good work, and has plenty of experience with LS and Erod setups.
Pacific fab/Tilden motorsports in Gilroy rebuilds and sells the engines (have one of their built 6.0L's in my 62 Impala.) But not sure they do installs anymore. Worth giving them a call though, they might be able to direct you to a shop closer to you.
Maybe once this Corona nonsense calms down start hitting the local cars n coffee meets, car shows and cruises, and ask around. Id guess there's a pretty stout car scene down by Fresno...
Old 04-17-2020, 11:26 PM   #9
MikeB
MikeB's Avatar
Will the CA smog Nazis be looking for all the emissions devices the 84 had, or do they just check tailpipe emissions? Still can't believe some states check emissions on cars and trucks 25 years or older, since they probably account for less than .01% of the vehicles on the road, and even a lower percentage of total miles driven.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-18-2020, 12:36 AM   #10
Ziegelsteinfaust
The erod kit comes with its own exhaust y pipe with converters, and the must be used.
All installs are different, but it is the evap emission equipment that must be utilized. How ever you get there is the tricky part. But I have it on good word that make it look good, and they go for it.
Old 04-18-2020, 10:33 AM   #11
Rickysnickers
Rickysnickers's Avatar
No, they look at the engine and make sure it has all the required equipment on it and that it hasn't been "tuned." Generally, a regular smog shop isn't going to touch it, the first time around. It would most likely end up at a referee station. There a couple of things they would look at on the actual truck as well. For instance if it is suppose to have the smaller nozzle opening for the gas fill.
Old 04-18-2020, 07:19 PM   #12
Loco83
Loco83's Avatar
The smog equip that go along with the old engine is taken out as the Erod is a stand alone system.
https://ww3.arb.ca.gov/msprog/afterm...o/d-126-30.pdf
Old 04-18-2020, 07:26 PM   #13
Loco83
Loco83's Avatar
Thanks for the info
Old 04-19-2020, 10:26 AM   #14
Rickysnickers
Yes, that's correct. I tried to say that, but it didn't come as a short as this response
Old 04-19-2020, 11:54 AM   #15
MikeB
MikeB's Avatar
That's pretty cool. Even meets CA standards. GM sure makes it easy.
Mike
Old 04-20-2020, 10:21 PM   #16
Ryan Hubbard
Be sure that your truck falls under the weight limit.
The LS3-6.2L V8 E-ROD Kit is a complete engine and emission control package designed to change engines from 1995 and older passenger cars and light duty trucks within the maximum weight limit (5725 lbs. GVWR)
My 1990 3/4t Suburban is over the rating and they will not allow me to have the LS3 E-Rod engine in my suburban. I am installing it in August and registering the car in Utah.
Ryan Hubbard is offline   Reply With Quote
Old 04-21-2020, 08:28 AM   #17
MikeB
MikeB's Avatar
Thus denying CA recurring income from registration fees. That's just crazy on their part. Just guessing here, but I suspect the new engine is cleaner than your original 1990 engine.
Mike
Old 04-21-2020, 09:56 AM   #18
Ziegelsteinfaust
The LS3-6.2L V8 E-ROD Kit is a complete engine and emission control package designed to change engines from 1995 and older passenger cars and light duty trucks within the maximum weight limit (5725 lbs. GVWR).
The erod package is not complete. You still need to tie it into your evaporative emissions your original vehicle has.
Old 04-21-2020, 11:43 AM   #19
Ryan Hubbard
No the Erod package is complete. You have to tie in the evap canister that is supplied with the engine. The kit comes complete with the cats and evap canister. The only thing is you have to supply the vent line from your gas tank.
Old 04-23-2020, 03:25 PM   #20
ShortHaul
ShortHaul's Avatar
I didn't know there was a GVWR limit on these... I googled it a bit but couldn't come up with any info, do you have a link?
:EDIT:
Did better googling and found it...
https://arb.parts/Executive-Order/D-126-32
Old 04-23-2020, 06:26 PM   #21
Loco83
Loco83's Avatar
What is the weight of a half ton short bed Silverado with the 305?
Old 04-24-2020, 02:07 AM   #22
ShortHaul
ShortHaul's Avatar
According to the GM Heritage site it looks like your GVWR would be between 4900 and 6100... depending on your transmission and rear end combo... remember GVWR is not the same as vehicle weight... its what your vehicle was rated to carry, including weight of the vehicle itself. It's usually stamped on a label on the inside of the drivers door...
Might be something I'd look into before dropping the $ on an E-rod setup. Or even swing by a smog referee shop and see what they say.
Old 04-24-2020, 07:31 AM   #23
Ryan Hubbard
I had a long conversation with the smog referee here in Orange County and he said they will let a vehicle slide that is a few hundred pounds over like 5850 but that is about it. He agreed that if I put it in my suburban I would actually lower the current emissions of my vehicle but that is the law and he has to follow it.
Old 04-29-2020, 11:07 AM   #24
MikeB
MikeB's Avatar
So, what has California accomplished here? Bureaucracy run amok.
Mike
Old 04-29-2020, 12:59 PM   #25
ShortHaul
ShortHaul's Avatar
That sucks. I have very little experience with the smog cops... which is why I only chase after pre-75 trucks... Every time I think its worth expanding my search I remember something like this and it scares me off.
