Tire Suggestions - Help
Good morning and hope everyone is staying healthy and safe.
So I will be running a 15x8 in the rear and a 255/60, and a 15x6 front rim. I originally considered running a 225/60 up front but I'm not sure if I will like the height of the tire compared to the rear. So the only other option Diamond Back offers would be a 215/70, and I'm afraid it will look too skinny. Truck is a 65 SWB on air ride. I originally had 235/70 all the way around but switched to wider wheels in the back and wanted to put new whitewalls on all the way around. Thoughts, suggestions? Am I just overthinking the height by looking at the tires off the rim? |
![]() Join Date: Aug 2004
Re: Tire Suggestions - Help
That 6” wheel might be a problem if you have disc brakes, go with a 7” or 8” if possible.
I run a 235/70/15 on 7” rally up front, then 275/60/15 on 8” rally in back, I have drop spindles/coils and rear airbags Posted via Mobile Device |
I'm currently still on drums for now. Do you have a side view of your truck?
#4 | |
Moderator
![]() ![]() Join Date: Aug 2011
#5 | |
front is 225-70-15 on 7 inch wheel, 2 3/4 inch ww
rear is 275-60-15 on 8 inch wheel, 3 inch ww all tires are diamondback.
1972 gmc 3500 ramp truck, 350, sm465, dana 70 rear |
Perfect! Thanks so much for the visual and beautiful truck
#8 | |
255/8 = 31.875 31.875 x 6 = 191.25 While a 205 is closest, the 215 you mentioned is a closer match of rubber per inch of wheel width vs. the 225. 255 x 60% = 6.02" sidewall height (27.04" OD) 215 x 70% = 5.92" sidewall height (26.85" OD). The height is slightly shorter vs. the rear but still fills the wheel opening vs an even shorter 225/60 @ 25.63" OD. The heights are based off of calculations & will vary slightly depending on the tire manufacturer.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-23-2020 at 02:38 PM. |
Scoti - thank you for the break down. I spoke with Diamond Back and they are sending me out the 215's and I'm sending back the 225's. I look forward to seeing this thing back down on the ground.
No problem.
| Bookmarks |
