Old 04-25-2020, 12:07 AM   #1
rod1701
rod1701's Avatar
PS bracket
Where can I get one of these?
Part number?
Off 67-72 or 73-87?
1979 C-10 LWB
rod1701 is offline   Reply With Quote
Old 04-25-2020, 12:11 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: PS bracket
look like 73-87 try rockauto,LMC,CLASSICPARTS
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-25-2020, 12:35 AM   #3
rod1701
rod1701's Avatar
Started there. No suck luck. Only found a couple of Google images. Nothing in any diagrams or part numbers.
Old 04-25-2020, 08:58 AM   #4
Pontiac1976
Re: PS bracket
#25 The front bracket S/P mounting is 73-78- C,K 350.
The rear bracket S/P support ASM ADJ is 73-78 C,K,P 350.<(This one not the most command used.)
would need more info: what it came in, what option on motor for belts run.
Then lots of Part # them to pick and that still hit miss un till can cross off a few.
This is just one book for 73-78 truck I checked. Group 6.606
Old 04-25-2020, 10:51 AM   #5
Rickysnickers
Rickysnickers's Avatar
Re: PS bracket
Try Fred, specialty retail, here on the board. He sells lots of stuff
Old 04-25-2020, 09:37 PM   #6
rod1701
rod1701's Avatar
I think that part would’ve perfect for what I am working on but improvised with old parts. Weak link seems to be the one bolt that that is mounting everything to the manifold. Seem strong enough. We’ll see when I drive a little.
Old 04-26-2020, 08:11 PM   #7
Pontiac1976
Re: PS bracket
If it work. But looking at your bracket it not the right one for the ex-manifold I think the one in the center works them.http://www.2040-parts.com/70-76-chev...elle-i2040599/
Old 04-26-2020, 10:29 PM   #8
rod1701
rod1701's Avatar
Re: PS bracket
Thanks. Like I said not happy with it but going to see if holds while keeping my eyes open at the local pick-a-part yards.
Tryouts g to get it back to pretty close to correct for the period. Seems like previous owners kept it up pretty good but maybe improvised with salvage yard parts available. Finding a few Impala and Chevelle pieces as well as 81-87 parts.
Going for a survivor/patina truck so definitely like used OEM stuff.
So far just under $300 under tff grr e hood with a few brackets, maintenance items, hoses, spray paint, plus gobs of carb cleaner/oven cleaner/degreaser, and tons of elbow grease.
1979 C-10 LWB
Old 04-27-2020, 01:19 AM   #9
Greasey Harley
Greasey Harley's Avatar
Re: PS bracket
I used an Alan Grove 400L in my 68' with a 327 and short water pump. I am quite happy with the quality and fit.
http://www.alangrovecomponents.com/S...Short_Pump.htm
Yours probably needs the bracket for the long water pump.
402L :
http://www.alangrovecomponents.com/S..._Long_Pump.htm
Greasey Harley is offline   Reply With Quote
