Old 06-13-2013, 09:17 PM   #1
Brad54
Brad54's Avatar
Trailing arm differences? '60-'62, '63-'66?
Are there any differences in the '60-'62 versus the '63-'66 trailing arms? Length, angle, etc.?
Thanks,
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 06-13-2013, 09:43 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: Trailing arm differences? '60-'62, '63-'66?
Thanks,
-Brad
I'm gonna say no MAJOR differences. I just sold a set of 1966 trailing arms with springs to a guy who installed them on his 1962. No problems with fitment at all. The 66 trucks had a different e-brake configuration and the trailing arms have a bracket riveted along the side, but functionally the trailing arms are the same. Also, LMC lists new trailing arms for 60-66 as the same part number, so that means you get the same part no matter for any 60-66.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-14-2013, 12:58 AM   #3
Budman56
Budman56's Avatar
There is a difference in the trailing arms when it comes to c20 and c10 the c20 have an extra steel plate at the rear of the arm both at the top and bottom and they are riveted to the arm these are heavy duty and were installed on the camper specials.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 06-14-2013, 08:35 AM   #4
Clyde65
Clyde65's Avatar
IIRC, the trailing arms are the same, but the cross member the arms bolt to are at different angles because the 60-62 TA are bolted to the axle closer to the backing plate than the 63-70's are.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-16-2013, 09:32 AM   #5
Brad54
Brad54's Avatar
That's what was going through my mind... I knew there was some difference somewhere.
-Brad
Old 04-24-2020, 09:43 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Yes, trailing arms are spread further apart because the frames are wider in the rear. I had to weld the perches further apart on the 65 12-bolt to work on my 62 frame.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-24-2020, 09:46 PM   #7
LostMy65
LostMy65's Avatar
I have those heavier duty ones on my 66 C20.
I'll try and get a pic.
Old 04-29-2020, 05:08 PM   #8
Vincenthdfan
Im considering installing a 64 12 bolt rear end in my 62 C10 in the near future.
My original Eaton rear end is leaking pretty bad from the pinion seal and rather than fight with it and worry about crush sleeve, etc...I figured I'd just swap it out with the 12 bolt.
I see you kept the original perches in place when you installed the new ones, did you have enough room to strike a good weld bead still (cant tell from the pic)?
Did you buy your perches from CaptainFab....mind telling me what they ran price wise?
Thanks!
Vincenthdfan is offline   Reply With Quote
Old 04-30-2020, 09:52 PM   #9
Captainfab
60-66 Nut
Here is the for sale thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=620836
Old 04-30-2020, 10:39 PM   #10
LostMy65
LostMy65's Avatar
Thanks!
Yes. I slapped the new ones (from cap't) right up against the ones on the 65 12-bolt. I welded what I could to the the axle and then welded the two perches together.
Old 05-01-2020, 01:03 PM   #11
Vincenthdfan
Originally Posted by Captainfab View Post
Thanks Captain Fab....hadnt seen that thread before. I'll be in touch soon!
Old 05-01-2020, 01:03 PM   #12
Vincenthdfan
Good to know, thank you.
