Old 05-16-2020, 11:35 PM   #1
337
1970 drum brakes 6 lug hub question
I need to replace driver side front hub for 1970 2wd 6 lug original drum setup.
Will the passenger side front hub work if it is all i can only locate?
Are the driver/passenger hubs interchangeable?
337 is offline   Reply With Quote
Old 05-16-2020, 11:46 PM   #2
gmc684x4
Re: 1970 drum brakes 6 lug hub question
I do not see why not front disc rotors with built in hub are left or right
gmc684x4 is offline   Reply With Quote
Old 05-16-2020, 11:56 PM   #3
custom10nut
custom10nut's Avatar
Why would you not buy a new one?
They’re not crazy expensive. And with a 50 year old used one you don’t know what you’re getting
custom10nut is offline   Reply With Quote
Old 05-17-2020, 12:12 AM   #4
337
Who makes new ones?
Or give me a recommendation on a new compatible replacement part.
Everyone goes the disc conversion route.
Doubt there is any money in a company making new drum hubs for these trucks which is why I need what is available.
A quick search on the site shows a few others had the same problem locating replacement drum hubs.
I am hoping those that do disc conversion dont trash or scrap those old useable parts just because they aren't modern.
Old 05-17-2020, 06:01 AM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I would think they're interchangeable from left to right. You need to be a supporting member to post a "want to buy ad" in the parts forum. But you can buy if someone has one advertised.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 05-17-2020, 09:08 AM   #6
Richard2112
Richard2112's Avatar
Check Rockauto. I got mine from them. It was a few years ago but..
Richard2112 is offline   Reply With Quote
Old 05-17-2020, 11:43 AM   #7
337
OK back To the original question, The driver and passenger side hubs interchangeable? Just looking for a Parts expert to give me a confident answer.
Old 05-17-2020, 04:28 PM   #8
RustyPile
RustyPile's Avatar
Retired automobile mechanic here.. Certified and experienced since 1966.. Front drums, hubs, seals, and bearings ARE interchangeable side to side on 1970 C/10 GM trucks..
RustyPile is offline   Reply With Quote
Old 05-17-2020, 04:57 PM   #9
337
Thank you for sharing your experience and knowledge!!!
Hopefully this will be useful to someone else in the future as it is to me.
Old 05-17-2020, 05:32 PM   #10
Getter-Done
Getter-Done's Avatar
Yes they are interchangeable.
There is no machine work on those parts that make them left or right specific.
The early bird gets the worm,
84 Chevy K-20
Old 05-17-2020, 06:32 PM   #11
68Gold/white
67-70 C-10 hubs ARE ALL interchangeable, and side to side!!!!
68Gold/white is offline   Reply With Quote
Old 05-18-2020, 12:01 AM   #12
'68OrangeSunshine
'68OrangeSunshine's Avatar
On my '68 C/10 the brake drums are interchangeable; left, right, front, back -- all same-same.
