Old 05-18-2020, 07:52 AM   #26
Afirehawk1
Re: Collapsible intermediate shaft?
Originally Posted by 65 GMC View Post
I have a 65 GMC with a 78 GMC power steering box. I used the collapsible shaft from the 78 GMC with an aftermarket u-joint from Sweet Mfg. It seems like it will work out pretty good. It also takes out any tension that would otherwise be on the steering column bearings from spacing the steering box out with an adaptor plate. Here are some photos of what I did before I welded it all in place. The last photo is the part# of the u-joint I used.
I did something similar.
I upgraded to a new steering box and installed with a new rag joint.
I have to recheck but i think i cut and attached the new shaft.
What makes this collapsible?
Is it the u joint? I didnt do that
Afirehawk1 is offline   Reply With Quote
Old 05-18-2020, 08:28 AM   #27
The Rocknrod
Moderator
The Rocknrod's Avatar
The shaft is the part that is collapsible on our truck IF you have a collapsible shaft.
Old 05-18-2020, 06:53 PM   #28
Afirehawk1
Mine is welded when the column was built
So i guess i should swap the whole thing
Old 05-18-2020, 08:45 PM   #29
Blue666(2)
I'm not sure when these were required as safety equipment but my steering shaft is from the mid-1970's. In the picture, I have put a white dot on the two shearable plastic pins that go through the two parts of the lower steering shaft. On impact, the plastic pins shear off and the outer shaft (which is a hollow tube) slides over the inner solid shaft.
If your shaft is welded or has the plastic pins replaced with metal bolts, it's no longer collapsable.
Blue666(2) is offline   Reply With Quote
Old 05-21-2020, 09:37 PM   #30
PGSigns
PGSigns's Avatar
Afirehawk yours is the stock shaft with the adapter on the end that comes with the power steering kits. This is a weld on process due to it not having a double D setup.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-22-2020, 09:13 AM   #31
Afirehawk1
Jimmy
thanks for the info.
i will be upgrading.
Old 05-22-2020, 08:31 PM   #32
Afirehawk1
Since I upgraded with A newer power steering unit, which collapsible shaft does everyone use? I think i used a 72 or 78 unit; so i need to remove the rag joint and count the splines?
Old 05-23-2020, 10:34 AM   #33
DonLeverton
Well, here's my plan ... which I hope to get going on right away, as soon as my truck gets back home from storage.
1966 GMC 910 pickup (Canadian 1/2 ton)
Early 70's G-van tilt column (3/4"-36 spline)
Jegs #607002 U-joint coupler (3/4"-36 spline to 3/4" DD)
1979 C20 collapsible intermediate shaft
1979 C20 power steering gear
The goal is to cut that goofy OEM "bell" coupler off of the intermediate shaft, then insert the 3/4" DD directly into the Jegs coupler.
I think it's going to be long enough to do that, but I did buy a length of 3/4" DD just in case.
DonLeverton is offline   Reply With Quote
Old 05-24-2020, 08:19 PM   #34
PGSigns
PGSigns's Avatar
That may work. On any adapter I use if it is not splined it gets welded or pinned. I do not trust the set screws.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-25-2020, 08:37 PM   #35
Blue666(2)
Jimmy
The Borgenson joint uses full length bolts that go through the lower end of the steering column & the upper end of the lower shaft. Not sure about the Jegs or other brands.
Also be sure to re install the ground connector from the lower shaft to the steering box across the rag joint or your horn won't work.
Old 06-05-2020, 04:23 PM   #36
Afirehawk1
I read on CPP website their collapsible shaft/ u joint is not recommended for stock columns.
So do we do?
Im confused
I have the 3/4, 36 spline gear box
Old 06-05-2020, 04:25 PM   #37
The Rocknrod
Moderator
That's because you have to modify the shaft on the column.
Old 06-05-2020, 04:37 PM   #38
Afirehawk1
any details exactly what has to be done because i have no idea.
do just I buy the u joint and install.?
do i change the shaft? if so who has them?
Old 06-05-2020, 05:06 PM   #39
The Rocknrod
Moderator
Pretty much what post 12 did on this thread. But by the way, if your not sure and wanting to do this yourself - Maybe you should get professional help on a something like steering and brakes. Your life depends on it.
Old 06-05-2020, 05:19 PM   #40
Afirehawk1
I was wanting to copy something that someone else did so i didnt have to re-event the wheel. I have this.
Old 06-07-2020, 07:08 PM   #41
DonLeverton
The G-van tilt column ( from what I’ve read) is the same as a 72 C10.
The 72 C10 used a collapsible steering shaft.
This swap has been done many times, and there are many ways to join the steering shaft to the power steering box.
I’m hoping to complete my install within the next couple of weeks, so
I’ll try to let you know if it goes according to plan.
Old 01-25-2021, 08:09 PM   #42
Afirehawk1
I used the 1977 Chevrolet c10 power steering box
The input spline count says its 26 from Masterpro
Suggestions then what intermediate shaft to use
I dont think the CPP-1DD730 will work
Thats a 3/4x30 spline unless im misunderstanding something
Need some advise on this one,
Old 01-26-2021, 10:31 AM   #43
DonLeverton
The system and parts described by me in a previous post in this thread worked out perfectly for me.
Van column (it actually has a 30 -spline output end)
Jegs U-joint (30 spline on one end, 3/4”DD on the other end)
Squarebody intermediate shaft with the top OEM coupler cut off
Rag joint
Steering box.
Old 01-26-2021, 02:36 PM   #44
Afirehawk1
so has anyone used a power steering gear box from late 70's (1977) C10?
the way i read the specs o the input shaft from MasterPro, there are 25 or 26 spline per their website. assuming that is not counting the flat spot on the shaft.
Wanting to order the CSS-1DD730 by CPP which is the 3/4-30 spline.
just want to verify this.
Old 01-26-2021, 08:08 PM   #45
cwcarpenter98
cwcarpenter98's Avatar
Count the splines on the gear you have and order the steering joint of your choice to match the gearbox. If you're running the stock style rag joint, they all use the same intermediate shaft bolt spacing
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-26-2021, 08:59 PM   #46
MT65
Thumbs up Re: Collapsible intermediate shaft?
You can take your shaft that’s in the original column, measure and cut it to the length, take the shaft to a mach shop and they can put the DD on it for you, I’ve done it many times......
You will need a bearing or bushing in the end of the column tube as well.....
MT65 is offline   Reply With Quote
Old 01-28-2021, 11:06 AM   #47
Afirehawk1
i figured it out.
The steering gear box has 25 splines showing. the flat spot on the shaft accounts for about 5. thus a 30 spline rag joint will work. i had to process this for a moment.
