Old 06-07-2020, 12:51 AM   #1
BAChevyMan
86 Scottsdale steering wheel.
I have an aftermarket steering wheel on my truck with a Grant Steering Wheel Installation Kit 3163. I was kinds wanting to revert to stock but have no ides what parts I would even need. Anyone provide any info on this?
BAChevyMan is offline   Reply With Quote
Old 06-07-2020, 05:39 AM   #2
4u2nv
Re: 86 Scottsdale steering wheel.
This may help you
4u2nv is offline   Reply With Quote
Old 06-07-2020, 09:26 AM   #3
BAChevyMan
Originally Posted by 4u2nv View Post
This may help you
Not really. So once I put the nut on, so thats #1 on the diagram... I just stick the steering wheel on top and add a 2nd nut?
Old 06-07-2020, 09:52 AM   #4
Dead Parrot
You need to have all of the horn button bits and those vary from wheel to wheel. Most pre airbag GM wheels will fit mechanically if not style wise. There is a spring backed contact that rides in the little cylinder on #7 that provides the horn circuit to the wheel.
IIRC - #1 is the nut that holds the wheel in place. #5 is a PITA lock ring that holds #6 in place.
If you are lucky the new wheel with match with the positioning of #7 and #6 and you can just pull the old wheel and install the new one. Sometimes you aren't lucky and have to remove #5 to adjust things.
This assume the Grant kit didn't replace some of the stock parts. You might be able to tell by pulling off the horn button on your current wheel.
Dead Parrot is offline   Reply With Quote
Old 06-10-2020, 09:45 AM   #5
Pontiac1976
Pontiac1976's Avatar
LMC on line. Would have a better pic on the horn parts you may need 3 screws bolts .
https://www.lmctruck.com/1973-87-che...ing-components
This should work {but this what it looks like}https://www.summitracing.com/int/parts/dck-882
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-10-2020, 11:28 AM   #6
truckin 79
Here is the grant install instructions
http://www.grantproducts.com/files/i...7508-00-01.pdf
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
