#5 | ||
Re: 73 C25 Leaky Gas Tank
65Oldred:
The other you can do is if the tank is still good is take it to a gas tank shop have them re-soldered if cheaper then new tank. But the tank still have to come out for the shop to work on it. If you bring the tank to them will be much cheaper for the bill.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
| Bookmarks |
