Old 06-28-2004, 04:15 AM   #1
apstguy
LED King
apstguy's Avatar
Leaking fluids
My rear main seal has always leaked but not bad at all. Recently the truck has been leaving puddles. It looks like the oil dipstick tube is leaking. Does it have an O-ring or sleave to seal it?
My tranny cooling lines leak just a tad. How can I stop them from leaking?
My rear differential has started leaking too. 3 leaks! Grrr!!! I guess it gives me me an excuse to change the rear cover to an aluminum or clear cover.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 06-28-2004, 07:00 AM   #2
bigblock73
yeller
bigblock73's Avatar
Dipstick tube has an O-ring...a new O-ring and a small amount of silicone sealer should fix that. I would put a little bit of teflon tape on the tranny cooler line threads, that should stop that leak.
bigblock73 is offline   Reply With Quote
Old 06-28-2004, 09:30 AM   #3
Grim Reaper
Tranny cooler line is a flare. If it's leaking then it is either not tight enough or the flare is damaged. Becarefull about over tightening into the side of the tranny. It's aluminum and can be stripped.
I think there is an adaptor there and if so where the adaptor fits into the tranny the Teflon tape is the ticket like bigblock73 said.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 06-28-2004, 09:40 AM   #4
screwballl
Tonawanda 454
screwballl's Avatar
since it is a flare fitting, teflon tape will ruin it and not let it seal properly, this is the case with all flare and compression fittings (i work at a hardware store i know these things )
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 06-29-2004, 01:22 AM   #5
apstguy
LED King
apstguy's Avatar
So how can you fix the flare or the compression fitting?
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 06-29-2004, 06:55 AM   #6
bigblock73
yeller
bigblock73's Avatar
I am talking about a very small amount of teflon tape, on the threads only. I have done this very same trick on my tranny lines once when I had a leak and the problem was solved. Some people go grazy with the teflon tape, but you really only need a small amount. I usually place it at the leading edge of the threads (away from the flare tho), and as you thread in the line, it will work its way back across all the threads...if this makes sense.
