Old 06-29-2004, 09:59 PM   #1
72superBB
72superBB's Avatar
Question OT: 93 Grand Prix AC problem
So my ac decides it only want to blow out the defrost and floor outlets, not the dash vents.
It does this on whatever I put it on. Could this be a vacume line problem or what?
1993 Pont Grnad Prix 3.1 liter v-6
Thanks for any input.
Ron
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 06-29-2004, 10:18 PM   #2
fast71
Drive it like U stole it
fast71's Avatar
yes ,, sounds like the vacuum line is off or broken.
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
fast71 is offline   Reply With Quote
Old 06-29-2004, 10:19 PM   #3
72superBB
72superBB's Avatar
anyone have a vacume diagram?
thanks
1990 Chevy SWB
Old 06-29-2004, 10:22 PM   #4
fast71
fast71's Avatar
should be one under the hood. look around the throttle body. one line should run to the inside of the car. theyre might be a vacuum ball under the hood
71 custom 10 swb
72 nova ss
72 nova custom
87 s10
96 burb
94 camry
53 5 window 3100
Old 06-29-2004, 10:25 PM   #5
Gee_Emm
Check around the firewall or under the battery. My GF's 94 GA was doing the same thing, the hard plastic line under the battery shattered, I spliced it up with a piece of hose and its been good ever since.
Only problem now is the damn car is running rich and I can't figure out why.
Gee_Emm is offline   Reply With Quote
Old 06-30-2004, 07:47 PM   #6
72superBB
72superBB's Avatar
anyone else?
thanks
1990 Chevy SWB
Old 07-01-2004, 07:42 AM   #7
mrein3
mrein3's Avatar
I wish I had a nickle for every cracked plastic GM vacuum hose I replaced with a piece of rubber hose.
Just find the crack or break, finish breaking it if it isn't busted clean, and reattach the two ends with a piece of hose.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-01-2004, 08:17 PM   #8
72superBB
72superBB's Avatar
I have looked and looked, but only found one vacume hose. The hose goes from the rights side of the motor to a metal tube that is hooked to the side of the wheel well and is curled down with an opening facing down. THe other thing it is doing is under normal to heavy accelaeration, the blowing from the fan stops almost completely.
I'll see if I can find a vacume diagram somewhere.
1990 Chevy SWB
