![]() Join Date: Jun 2012
Re: Help with Steering Shaft Removal
I would first soak the end with a good penetrating oil. Next, disconnect the shaft at the rag joint and get it off the steering box then try to hammer it off using an adjustable wrench around the shaft and striking with a hammer. The shaft is sorta of D shaped and is a really tight fit. When you go to reinstall clean both the intermediate shaft end and the steering column shaft end with some sand cloth and make sure it is positioned properly. Good luck sometimes they are a pain in the butt.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
| Bookmarks |
