Old 08-04-2020, 09:10 AM   #401
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Originally Posted by Ol Blue K20 View Post
Looking good, starting to come together.
Thanks...one step at a time.
fishnixon is offline   Reply With Quote
Old 08-06-2020, 11:47 AM   #402
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
After the V8 engine crossmember was in, I removed the 6cyl transmission mount and put in the V8 crossmember.
Old 08-06-2020, 01:45 PM   #403
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Dumptruck Dolly
Looking good, it'll be a truck in no time.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-10-2020, 12:15 AM   #404
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thanks...yes, soon
Old 08-10-2020, 12:22 AM   #405
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I used the 2 post lift to handle the drop in procedure. Here’s my brother, Terry, on the left and friend, Randy, on the right tackling the motor mount bolt. It gave us a little trouble, but soon complied.
The next photo shows my son, Trevor, finishing up the header bolts.
The measurements from the K20 onto the “K30” went well. My crossmembers we’re located like factory. Yes!!
Old 08-10-2020, 12:25 AM   #406
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
There it is...motor, transmission and transfer case have found their new home. Feels great!
Old 08-10-2020, 05:21 AM   #407
Ol Blue K20
Re: Dumptruck Dolly
Looks great too.
Dale
Old 08-10-2020, 05:46 AM   #408
72 tigger
72 tigger's Avatar
Re: Dumptruck Dolly
Has to feel good having it come together. Looks great
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 08-10-2020, 07:34 AM   #409
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Looks great too.
Old 08-10-2020, 07:34 AM   #410
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Very much so...thanks
Old 08-10-2020, 02:40 PM   #411
68Gold/white
Re: Dumptruck Dolly
Are those bias tires on front???? Just ask'n...
68Gold/white is offline   Reply With Quote
Old 08-10-2020, 10:19 PM   #412
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Bias all the way around
Old 08-10-2020, 10:33 PM   #413
Getter-Done
Getter-Done's Avatar
Re: Dumptruck Dolly
Thumbs Up.
Great Job
The early bird gets the worm,
84 Chevy K-20
Old 08-11-2020, 08:00 AM   #414
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Originally Posted by Getter-Done View Post
Thumbs Up.
Great Job
Thanks 👍
Old 08-16-2020, 11:50 PM   #415
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I am trying to do something everyday on the truck...My days are packed with family stuff, BBQing some onion burgers and chicken legs, plus I had to diagnose an overheating issue on my CRX. Turns out it is a coolant temperature switch that activates the fans. Order the part tomorrow, replace on Tuesday...Anyway, I scavenged the shock mounts from the Blue Beast, repaired the metal where I torched it too much, painted the mounts, plus the shocks and applied new hardware. Oh yeah, and I cleaned up the starter, painted it and secured it on the 350. It wasn’t glorious, but this is the stuff that has to happen and maybe isn’t covered too much in these swaps.
Old 08-17-2020, 04:18 AM   #416
Average Joe
Average Joe's Avatar
Re: Dumptruck Dolly
Nice work! Amazing how all the little things add up time wise.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 08-17-2020, 07:22 AM   #417
Ol Blue K20
Re: Dumptruck Dolly
It's looking good. A little at a time leads to a lot accomplished.
Dale
Old 08-17-2020, 11:18 PM   #418
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thank you...looking for bolts, scuffing paint, waiting for paint to dry, etc...time flies
Old 08-17-2020, 11:23 PM   #419
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thanks...and knowing I won’t have a regret regarding, ie painting the shocks, sure does feel good. Having my son around watching and helping is fun, and hopefully some good things are passed on to him regarding even the “small things”.
Old 08-22-2020, 06:34 PM   #420
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Dropped in the distributor, ran the plug wires and fastened it with an old project’s fancy hardware.
Old 08-22-2020, 06:38 PM   #421
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Side view...for some reason I’m still thinking about orange valve covers.
Old 08-23-2020, 11:18 PM   #422
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Waiting for parts for the motor. I decided to tackle the 3rd member swap...Dolly’s rearend ratio is 5.14...the front axle ratio is 4.55. The donor’s rear axle is the same floater style as the dually.
Old 08-23-2020, 11:26 PM   #423
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Cleaned up the mating surfaces, put on a high quality gasket sealer, and wrestled up the 4.55 3rd member into place, and put the floating axles back in...Yes!
Old 08-24-2020, 09:41 AM   #424
68Gold/white
Re: Dumptruck Dolly
You're going from a grandma rear end gear to a younger grandma rear end gear...
Old 08-24-2020, 10:13 AM   #425
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
You're right...It'll help just a little, but at least they'll match and I'm using up parts I have on hand. Decreasing my stockpile is also a goal in this build.
