Old 01-17-2018, 07:29 AM   #776
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: Post Your Straight Six Pics!
Originally Posted by Rwsmith66@yahoo.com View Post
Here is my Mercruiser marine motor fresh off,I mean out of the boat. My version of a IL6 conversion! And it's not for sail!!!
So cool. I have the valve cover but I'm still on the lookout for a set of those side covers.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 01-17-2018, 12:34 PM   #777
RichardJ
bitsa ?
reco'd ?
Not everyone, including myself, does well with made-up texting language, especially half way around the world.
This would be a good time to remove the end locator pins at both ends of the head. They have the same threads as the other manifold mounting holes and would help in holding the extra weight of the blower.
Also a good time to see if the bottom of the block needs drilled for a bolt-up starter.
If you later decide on a mini-starter or even an automatic, you don't want to be drilling from underneath after the engine is installed.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 01-17-2018, 12:42 PM   #778
palallin
Originally Posted by IRQVET View Post
Not eye candy by any means, but here is the 292 out of my 68 C-20 . . .
On the contrary: this kind of pic is just what I like to see.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 01-17-2018, 06:57 PM   #779
VWNate1
VWNate1's Avatar
Post Re: Post Your Straight Six Pics!
"BITSA" isn't made up, you just don't know it - it means made from Bits Of This And Bits Of That .
Using fasteners in the ends of any InLine exhaust manifold is the fastest way to force it to break .
Reco'd means reconditioned, nothing new there either .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 01-17-2018, 08:15 PM   #780
RichardJ
Actually, reco'd is a closer fit to "recommended".
bitsa, meaning "back in the saddle again", oh wait, it's a British tv show, or in the urban dictionary, "A person of no fixed nationality". Not in a real dictionary.
I'm betting you made a guess at the meaning of both, but you didn't notice the pre-made header flange bolted to the head. He also stated he would be building his own EX headers.
The flanges look like the ones, Mr Hotrod 6 sells and are two-piece.
Old 01-17-2018, 08:24 PM   #781
VWNate1
VWNate1's Avatar
No ;
i'm old and have been in the Auto Trade since before this engine was built, I know what I'm talking about .
-Nate
Geezer
Old 01-17-2018, 11:14 PM   #782
sharpmark
sorry about our lingo (language).
bitsa - bits an pieces from different things ( motors)
recoed -reconditioned.
VWNate1 was correct.
the inlet an exhaust flanges were plasma cut off my drawings I made off a gasket.
was looking at those end studs and will probably replace with bolts and the blower will definitely have more support then just the row of bolts.
thanks for the interest.
1969 stepside-305/4spd/12 bolt posi
http://67-72chevytrucks.com/vboard/s...d.php?t=477157
1968 pontiac lemans convertible-350/pwrglde/10 bolt
1934 oldsmobile sedan-350/350/12 bolt posi
1930 model a pickup-350/350/jag ind
1928 model a roadster-283/350/9"
sharpmark is offline   Reply With Quote
Old 01-17-2018, 11:45 PM   #783
RichardJ
I used no bolts. Threaded studs are install in all manifold holes.
In this picture, not one nut has been installed and it's all resting in place. The original GM setup with only two studs, made it so difficult to get everything in place and the bolts started.
Your flanges look so similar to https://mrhotrod6.myshopify.com/prod...ant=1142523877 I thought it might be the same.
Old 01-19-2018, 03:53 PM   #784
VWNate1
VWNate1's Avatar
Thumbs up Re: Post Your Straight Six Pics!
Multiple countries separated by a 'common language' .
I hope we get some video with sound of this beast when it runs .
-Nate
Geezer
Old 08-18-2020, 04:09 AM   #785
Randy S. Hager
Randy S. Hager's Avatar
REVIVAL...….yeah let see some more recent pictures of the chevy inline 6 engines. Here is one I pinched off a site called Mercado Livre (eBay of Latin America-Brazil) I'm getting my friend down there to buy me that kind of intake for my 250 and also that really nice valve cover.
Cheers
Randy
Randy S. Hager is offline   Reply With Quote
Old 08-18-2020, 11:55 AM   #786
VWNate1
VWNate1's Avatar
Thank you .
-Nate
Geezer
Old 08-18-2020, 12:47 PM   #787
crazyjeenyus
crazyjeenyus's Avatar
292 in process
+.040" Silv-O-Lite flat tops
Lump ported head
comp 280h single profile cam
4-Barrell intake & Holley 390cfm
Transmission??? TBD
'67 c10
'65 c10
crazyjeenyus is offline   Reply With Quote
Old 08-18-2020, 06:31 PM   #788
'68OrangeSunshine
'68OrangeSunshine's Avatar
Cheers
Randy
So that is NOT a Clifford intake?
Tom Lowe at www.12-bolt.com
Sometimes has those valve covers.
Old 02-21-2022, 01:58 AM   #789
JAV6
JAV6's Avatar
Here is my daily driver, 1968 GMC 1500 with original 292, currently a work in progress. Kept having problems with the monojet so I finally jumped all in with a 4 barrel conversion. Learning a ton from these posts, thank you.
1968 GMC 1500 LWB 350 V8/TH700R4
1970 CST-10 SWB 350 V8/3-Spd Saginaw
1967 C-10
JAV6 is offline   Reply With Quote
Old 02-21-2022, 04:04 PM   #790
'68OrangeSunshine
JAV6 --Sweet looking L6.
What carb is that?
I have the same Offy intake, with Clifford headers and an Edelbrock 1404 [500 CFM] 4 barrel. And HEI.
My 292 is also the original. I rebuilt a '67 block and ran that one for 25 years, before I rebuilt the OEM block. Back on the road in 2005.
Bottom pic is from build up.
Old 02-21-2022, 04:14 PM   #791
old51sedan
old51sedan's Avatar
This looks like a good way to go in my opinion, here is a few pictures of my 292. I turned my Holley 90 degrees so that it would face forward. I have the cast iron headers and using a 200-4R transmission.
old51sedan is offline   Reply With Quote
Old 02-21-2022, 04:25 PM   #792
'68OrangeSunshine
I've had debates with guys over what orientation a 4 bbl carb should be on a modified L6. My personal opinion -- and I am no High Performance expert -- is that with the carb looking ''sidesaddle'' the primaries open up to the cylinders evenly. With a 90* pitch, 4-5-6 will get the full blast of opening secondaries first.
Experts tell me it doesn't matter.
If transmission linkage is an issue, I can see using that configuration. I cut the Ford kick-down parts off my Holley 390 -- I run the SM465 manual.
Very neat A/C set up, BTW.
Old 02-21-2022, 10:15 PM   #793
JAV6
JAV6's Avatar
What carb is that?
68Orange,
Thank you, It's an Edelbrock 500CFM AVS2, I went along a similar route as you just oriented it towards the valve cover. I believe it set up the ideal location for the Lokar throttle cables towards the front. The AVS2 also allows me to use either side for a fuel inlet. With any luck it will run well.
1967 C-10
Old 02-21-2022, 10:43 PM   #794
'68OrangeSunshine
Cool. I converted my '68 to a '72-style throttle cable too. My choke cable is forward, and the throttle lever is aft. That way the air/fuel mixture screws point to the drivers fender -- easy to work on.
The old bellcrank linkage to my old Holley 390 CFM was too clunky. It could bind, drop out parts, and once even froze up with rime ice at high RPM driving home in the mountains from a ski trip. I had to use the clutch rather judiciously and shut off the ignition when I got to a burger stand for a break. After half an hour at the warmer temps at the lower altitude, the carb-ice broke off.
I ran the Holley for 25 years until right after the 500-mile break-in on the current 292, and the Holley went out on a backfire. It would not let itself be set up again, even after a fresh power valve. Manifold leakage due to a warped carb base was suspected. Rather than repair a 25 year old carb with a new base plate, it was cheaper to get a new Edelbrock.
The Performer Series are clones of the old Carter AFB [Aluminum Four Barrel] carbs. The Thunderor Series are copies of the old Carter AVS [Aluminum Vacuum Secondary], except that the Carter AVS had three step metering rods and cupped jets. That allowed an intermediate power stage to be set up -- like for towing. Edelbrock changed out their AVS for a two stage Rod and Jet system, same as on the AFB.
I found an abused, discarded AVS carb among some movie props, and bought parts for it, but the secondary stage is only some small spray nozzles, not the annular rings found in most big carbs. I have not tried it. The numbers show it was for a Big Block Mopar, once. Maybe it came off one of the many studio-trashed General Lees? No one will ever know.
Old 02-22-2022, 10:13 AM   #795
old51sedan
old51sedan's Avatar
I understand your logic, but to me it was about the way I thought the carb should be facing. Also connecting the linkage for both throttle and transmission seemed easier to me. That being said it seems to perform just great even though I have only made a few short trips with it. One bad thing about it sitting this way is if you need to adjust the hight speed idle you have to pull the carb to adjust it, but once done everything's fine.
Old 02-22-2022, 03:30 PM   #796
'68OrangeSunshine
With my Edselbrock facing left, all I have to do to adjust air/fuel mixture and idle is lean over the driver's side fender. Just sayin'...
Old 02-22-2022, 05:21 PM   #797
RichardJ
AVS actually stands for "Air Valve Secondary". I've had a Carter AVS on my 292 for about 18 years now.
My throttle cable loops around and over the valve cover. My original, but modified oil bath was even farther modified after this picture to contain a paper filter. I tried, but never could get it to stop leaking oil all over itself.
I looked at the 4bbl carb orientation from the viewpoint of intake manifold runner length. Generally long runner lengths are better for low rpm and short runners work better for high rpm engine power. An inline engine with a single center mount presents a mix of both and a slight imbalance. Inline engines with a single center mount tend to run lean in the end cylinders and richer in the center cylinders.
If you use a string or narrow tape measure to check the distance from the head flange to the carb primary valve it is very long for cyl 1,2 as well as cyl 5,6. Cyl 3,4 is very, very short, especially if both primaries are inboard.
On my Clifford, the inboard ports are only about 4" from the 3,4 head flange, but the outboard ports are 6". The forward primary port is 11" from the 1.2 flange and the rear primary port is the same 11" to the 5,6 flange.
6" vs 11" isn't ideal, but a lot better that 4" vs 11" if both primary throttles are inboard.
If the carb is turned 90* to the head, one primary is 4", the other 6" from the 3,4 flange. Two primaries are 10" from the 1.2 flange and 12" from the 5,6 flange.
Truth be told, it doesn't seem to make a bit of difference, especially from the seat of the pants of most drivers with that setup.
Personally, the thought of that intentional imbalance drives me crazy.
The real world advantage of the sideways carb is the original style throttle rod linkage.
You might think that at WOT, all ports are equal distance in any orientation, but most of these carbs have smaller primary bores. Only the Carter AVS used on the 440 had 1 11/16" x 1 11/16" pri/sec bore. The Ed 800cfm AVS2 has even larger 1.75" x 1.75" pri/sec. All the other AVS carbs use smaller primaries.
Old 02-22-2022, 09:25 PM   #798
JAV6
JAV6's Avatar
Richard J and 68Orange,
You both make great points on the carb orientation and there seems to be many ways to skin the cat. Interestingly enough the Offy instructions recommend to position the primaries inboard. Still a work in progress, had to go to a 7" K&N filter to clear the brake booster. Richard I like your air filter setup, I wish I could have kept mine but it just wouldn't work in the current config.
1967 C-10
Old 02-23-2022, 01:06 AM   #799
'68OrangeSunshine
JAV 6 Cool rig.
Richard, you rock it Dude.
A/C, P/S, L-25 292.
No heater needed in SoCal?
JAV6
I have a paper filter, on a 12'' Morose sombrero, aftermarket air cleaner. When I ditched the Monojet years ago, I lost a lot of stock connections.
I have a K&N element for it, but I'm leary of K+N parts, as they are flammable in an engine fire. Also shy of plastic fuel filters, as they can melt and spray gas all over the engine bay if exposed to very high temps.
[Those are the names of the demons that took down my '67 K/10 Suburban, w/454. Learned it the hard way.]
Old 02-23-2022, 12:51 PM   #800
RichardJ
I gained 4-5 inches of clearance around the carb by bolting the brake booster directly to the firewall and eliminating that brake rod bell crank linkage.
I think Offy may have suggested that orientation back in the '60s when they offered this bell crank setup that was supposed to connect to the original auto kick down rod and throttle rod.
Your Lokar cable didn't exist for another 20 years after this manifold was first introduced.
