Old 08-19-2020, 05:15 PM   #3
SCOTI
SCOTI's Avatar
Re: Receiver Hitch
Originally Posted by TrybalRage View Post
I don't think it will work.. I believe the frames are different widths, and you'll likely not have the right mounting hole locations.
Same widths. Different probable bolt hole locations. I used the 'hidden hitch' I purchased from ECE for my 68 on my 74 swb when it took over tug-boat duties. I had to tweak the bracket slightly so it cleared the rear shackle bracket but 4 of the 6bolts aligned beyond that.
Bought a 2nd ECE 'hidden' unit from ECE & it's under my dually now.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
