camper mirrors help
Does anyone know where I can find or buy a set of camper mirror like these? Thank Rick
What Hump?
Re: camper mirrors help
Check out Short Hauls thread in Square Body and Builds "Bourbon" 1975 Suburban Scottsdale" He said:
"I tried out a new set from Petersen Lighting, their "810" model, which lists as a universal fitm but it turns out the lower arms are a few inches shorter than the originals." So other than that he said to look around at wrecking yards & CL
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
Thanks this will help
Moderator
![]() Join Date: Oct 2008
The early CK tripod mirrors tend to tear the door skins at the mounting points.
You can Frankenstein a set of large glass power dumbo mirrors that work quite well for towing and don't look out of place on the CK trucks. Merge the Dumbo door mount from the CK & RV trucks with the 90's G series van stem and power mirror.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
What Hump?
There to be some on Tucsons cl
https://tucson.craigslist.org/pts/d/...139454307.html
Go to a big truck parts store and see if they have what you want. The one close to me has those mirrors and door mounts
![]() Join Date: Apr 2018
Rick, I’ve been on the hunt for a set for some time, my 75 Burb came with those mirrors originally, and the mounting holes are still visible in the doors. As Eyegore mentioned above I’ve tried and failed at sourcing a new set from Peterson lighting... they look identical but don’t match up to the holes. My question for you is, are the mounting holes in the door there? Or are you just trying to add a set of camper mirrors where there were none before?
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
A lot of those original four point below eyeline mirrors got ripped off and the doors destroyed by women drivers
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
#9 | |
What Hump?
#10 | |
![]() Join Date: Jul 2007
There used to be a set of those in my junk pile before I loaded up that stuff for scrap.
They are about the quickest way to mess up a good door as anything you will find. My uncle had something like those on my 71 when he had it and hit stuff and destroyed both doors.
#12 | |
Do you have the mirrors in ok shape or do you need brackets or need complete mirror and Brackets. The after market Truck supplier of the day and all the short reg 3 bolt point mount mirror fit the Brackets that way it may give you more options. Did have set of Brackets over the hot water tank yr's till the tank blow because I wanted larger mirror again I had found no nice used reg short 3 bolt point mount mirrors then found 4 or 5 bolt point mount set mirror just used the mirror's .
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
| Bookmarks |
