72 burby fuel tank sending unit with return line?
My 1972 Highlander Suburban has a fuel tank sending unit with a supply and return line, yet my LMC stock replacement arrived with only one supply line.
Do they make a single line sending unit or do I replace the fuel pump and disregard any return lines? |
![]() Join Date: Feb 2016
Re: 72 burby fuel tank sending unit with return line?
If the correct unit isn't available I would modify your new one. I soldered a return line into the sender on my Burban. See photos in the link.
https://67-72chevytrucks.com/vboard/...698377&page=16
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
I'm trying to install my LMC replacement tank and the filler neck is too short? It will kink the rubber filler line as it comes out of the tank. Do you have to transfer the old filler neck to the new tank or do I have the wrong tank...
This thread is probably the answer to your question. If not do a search as this is a known issue and several fixes are out there.
http://67-72chevytrucks.com/vboard/s...d.php?t=779043
When I replaced the fuel tank on my Suburban I cut off the filler neck and welded it to the new tank.
