Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 08-31-2020, 08:54 PM   #26
VictoriaHardware
VictoriaHardware's Avatar
Re: K1416 Suburban part-out- Rolling Chassis
Originally Posted by 1960chevypanel View Post
Ok I'll take those
Here are pics. Weighs 4# shipped.
VictoriaHardware is offline   Reply With Quote
Old 09-02-2020, 06:23 PM   #27
wcstory
wcstory's Avatar
Originally Posted by VictoriaHardware View Post
Is this what you need?
Sorry for the delay.
Yes that is it. How much? It should fit in a flat rate box.
1966 GMC 1 Ton 305 V6 SM420 4 speed - retired Fire Dept Support Truck from Little Falls, NJ
My GMC Photos
wcstory is offline   Reply With Quote
Old 09-03-2020, 08:58 AM   #28
VictoriaHardware
I really don't know how to price this other than I know how much time I have in it. How does $25 sound? It does fit in a USPS Large Flat Rate box, so total would be 25+21.10+PP fees. PM sent for payment info should you want it.
SOLD
Old 09-04-2020, 08:12 AM   #29
southern parts
southern parts's Avatar
i`m interested in the rod between the ps gear box and the front axle. how much shipped to elberton ga 30635 ?
southern parts is offline   Reply With Quote
Old 09-04-2020, 09:50 AM   #30
VictoriaHardware
Not sure which one you're talking about. In this pic there's the Pitman arm, some other rod with tie rod ends on it, and another arm bolted to the knuckle. I can tell you the "tie rod part" is homemade.
Old 09-04-2020, 05:02 PM   #31
southern parts
I hesitated to call it a tie rod because I knew it had to be homemade. I have a 68 Suburban with closed knuckle front end that I'm trying to add power steering to. Does it look cobbled together or like somebody did a decent job?
Old 09-05-2020, 10:14 AM   #32
VictoriaHardware
Actually not bad. The one tie rod end is welded to the sleeve. How about $15? Shipping weight is 5# and it will fit in a Med Flat Rate box @ $15.50
SOLD
Old 09-11-2020, 06:47 PM   #33
wcstory
wcstory's Avatar
Parts arrived today. Well packed and in the condition depicted.
Thank you
My GMC Photos
Old 09-11-2020, 08:38 PM   #34
1960chevypanel
Got the mounts, thanks. Do you have this brace?
1960chevypanel is online now   Reply With Quote
Old 09-12-2020, 09:17 PM   #35
VictoriaHardware
I assume you're talking about the crossmember. It's heavily rust pitted and has part of a trailer hitch welded to it. It also got chunks cut off when the rest was cut with a torch. So it's not better than what you have now.
Old 09-13-2020, 04:56 PM   #36
VictoriaHardware
Parts remaining- prices plus shipping & PP fees
Axle, front $200
'65 Dana 44 Closed Knuckle, 3.73, open carrier, 6 lug, excellent condition, no shipping
Axle, rear $50 SOLD
'65 3.73, open carrier, 6 lug, fair condition, no shipping
Transmission $200 SOLD
'69 SM465 4 spd, no shipping
Cylinder Heads, 3932441 $100 SOLD
Both dated A-9-9. bare castings
Steering Gear w/ pitman arm $125
Integral box, '69 (?)
Old 09-13-2020, 05:00 PM   #37
VictoriaHardware
Crossmember $75
K10 manual transmission, with spring mounts and hardware
Lift blocks $50 SOLD
cast iron, rear axle, with clamps
Jounce Bumper Blocks $25
cast iron, front axle
Spring Mounts $25 ea SOLD
Front - forward LH, forward RH
Rear - forward LH, forward RH, rearward RH
Old 09-13-2020, 05:01 PM   #38
VictoriaHardware
Brass Fittings- $25 SOLD
brake plumbing, 4 pcs
Clutch Linkage $25
Frame bracket, cross shaft, Rod, Lever w/ Hardware
Old 09-13-2020, 05:25 PM   #39
1960chevypanel
Ok thanks for checking on it
Old 09-15-2020, 07:33 AM   #40
whateverpratt
How bad are the suburban/panel/carryall specific rear frame pieces, or do you still have them at all?
'66 c10 rust bucket, 350 (pulled and sold, now waiting on 4bt install) nv4500 stock bellhousing, '85 c30 front suspension and 3/4 rear coils with 4.10 H072 rear axle
NV4500 install http://67-72chevytrucks.com/vboard/s....php?p=6488778
Suspension update http://67-72chevytrucks.com/vboard/s....php?p=8236775
whateverpratt is offline   Reply With Quote
Old 09-15-2020, 08:59 PM   #41
VictoriaHardware
Rest of the truck had a hot date with the torch.
Old 09-15-2020, 11:17 PM   #42
chtr65
I will take the brass fittings for brake lines.
chtr65 is offline   Reply With Quote
Old 09-16-2020, 04:01 PM   #43
aotte1
How are the front horns, what price are they? I will take depending on price.
Cut behind the motor mounts and include radiator crossmember. Send photos please of frame as is now.
Price on the front spring Mounting brackets, will take pending price.
Price for rear spring shackles front and rear, will take pending price. Will you take 100 for the five of them?
aotte1 is offline   Reply With Quote
Old 09-16-2020, 04:34 PM   #44
aotte1
I will take the transfer case shift linkage pending price/shipping.
Photo of needed parts circled in yellow. All except pins in TC.
Old 09-16-2020, 08:45 PM   #45
VictoriaHardware
Frame horns- cracked & bent. Not bad but not perfect. I will get pics tomorrow
Rad crossmember- pics tomorrow
Rest of frame - pics tomorrow
Spring mounts- $100 for 5 is OK
Transfer case & all associated parts are already sold
Old 09-16-2020, 09:03 PM   #46
aotte1
I will take the 5 spring mounts. Maybe ship in large Usps flats rate box.
Ok if wait, to pay until we finish if getting additional parts after tomorrow Pictures.
Thanks,
Old 09-17-2020, 12:04 PM   #47
VictoriaHardware
Rad crossmember- Some rust, couple nicks from the torch, but very usable. Truck had never been in an accident so part is straight $20
Old 09-17-2020, 12:06 PM   #48
VictoriaHardware
Frame horns- cracked & bent, some rust $20/pr
Rest of frame - Sad picture. Valued @ $.50 in scrap steel
Old 09-17-2020, 04:47 PM   #49
aotte1
Thanks for pictures:
Will take the front frame horns.
And left front frame rail sections circled in yellow. Will confirm with you frame rail needEd on left side with engine mount in more detail. Do you have frame right side engine mount/perch? Will take if you have too.
Also in second photo, do you have both side of rear frame circled in yellow?
Third photo below do you have the body mount circled both side?
Old 09-17-2020, 08:55 PM   #50
VictoriaHardware
left front frame rail sections circled in yellow. ... with engine mount in more detail.
LH front section has numerous extra holes and welding where a non-factory power steering box was. Not bad rust though.
Next LH frame section is not bad rust-wise. Factory engine mount is good. Truck was originally a 292 six.
RH engine mount is not original- see bolts. A 350 V8 had been transplanted and the RH engine mount did not fit correctly. In fact the RH side of the engine was held in by gravity, so I don't think this will be of any good to you.
