Old 12-06-2020, 04:21 PM   #1
georgieb51
georgieb51's Avatar
Re: Has anyone cut the lens off from a sealed beam headlight?
What is the relay harness mentioned by a few fellows?
1972 Chevy Custom Deluxe Highlander, owned 34 years.
1970 GMC Sierra Grande 2500, unrestored, original.
1970 Chevy K10 Short Wide-bed, working on restoration..
1967 Chevy K10 Short Stepside, unrestored original.
1969 GMC CST (Longhorn) 396, buckets, unrestored.
1995 GMC K2500, 65,000 miles, 454.
georgieb51 is offline   Reply With Quote
Old 12-06-2020, 04:55 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
You connect the relays to the battery and the headlights. When you turn on the headlights, power goes through the relays to the headlights instead of roundy-round from the battery to the headlight switch, dimmer switch and then to the headlights. Much less voltage drop. Here is a thread I made to show the difference from stock to using the relays. I bought them from LMC.
http://67-72chevytrucks.com/vboard/s...d.php?t=782071
~Steven
Simi Valley, CA
Old 12-06-2020, 06:19 PM   #3
georgieb51
georgieb51's Avatar
Thanks . I will give that a try. BTW I noticed your grill and bumper changes in your photos. creative thinking goin on there!
Old 12-06-2020, 07:05 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
My FiL did that. I don't know if it got hit, or what. I'd like to go back to the original, someday.
~Steven
Simi Valley, CA
Old 12-06-2020, 05:24 PM   #5
truckster
truckster's Avatar
You can buy the harness from various vendors, or you can make your own. The wiring isn't really difficult.
The idea is that instead of running the amperage for the headlights through the switch, you control the relays with the switch. Full amperage runs through the relay to the headlights. It preserves the switch and gives full voltage and amperage to the headlights, resulting in a brighter light.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
