Old 12-06-2020, 05:24 PM   #26
truckster
truckster's Avatar
Re: Has anyone cut the lens off from a sealed beam headlight?
Originally Posted by georgieb51 View Post
What is the relay harness mentioned by a few fellows?
You can buy the harness from various vendors, or you can make your own. The wiring isn't really difficult.
The idea is that instead of running the amperage for the headlights through the switch, you control the relays with the switch. Full amperage runs through the relay to the headlights. It preserves the switch and gives full voltage and amperage to the headlights, resulting in a brighter light.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 12-06-2020, 06:19 PM   #27
georgieb51
georgieb51's Avatar
Originally Posted by Steeveedee View Post
You connect the relays to the battery and the headlights. When you turn on the headlights, power goes through the relays to the headlights instead of roundy-round from the battery to the headlight switch, dimmer switch and then to the headlights. Much less voltage drop. Here is a thread I made to show the difference from stock to using the relays. I bought them from LMC.
http://67-72chevytrucks.com/vboard/s...d.php?t=782071
Thanks . I will give that a try. BTW I noticed your grill and bumper changes in your photos. creative thinking goin on there!
1972 Chevy Custom Deluxe Highlander, owned 34 years.
1970 GMC Sierra Grande 2500, unrestored, original.
1970 Chevy K10 Short Wide-bed, working on restoration..
1967 Chevy K10 Short Stepside, unrestored original.
1969 GMC CST (Longhorn) 396, buckets, unrestored.
1995 GMC K2500, 65,000 miles, 454.
georgieb51 is offline   Reply With Quote
Old 12-06-2020, 06:23 PM   #28
Getter-Done
Getter-Done's Avatar
Originally Posted by chewychevy67 View Post
I Wil post the results. I will try it on a different bulb first. I may try a few ideas. I just hope something will work. If you have any links to videos or such where ppl have split these bulbs please post them.
Here is another article for idea's.
Link:https://www.jalopyjournal.com/forum/...ights.1209713/
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 12-06-2020, 07:05 PM   #29
Steeveedee
Who Changed This?
Steeveedee's Avatar
My FiL did that. I don't know if it got hit, or what. I'd like to go back to the original, someday.
~Steven
Simi Valley, CA
Old 12-07-2020, 12:13 AM   #30
chewychevy67
When I do this I'll do the 1st one comple and compare it to the others before I o them all. I know it's probably illegal and I will check the glare before I drive with them. If they glare bad they will just become art pieces I guess.
chewychevy67 is offline   Reply With Quote
Old 12-07-2020, 04:19 PM   #31
chewychevy67
I have researched led bulbs a bit and I came across these. I may contact these ppl once I have my bulbs done. They seem very knowledgeable. The led they are displaying here is moveable so that may help me in this situation. https://youtu.be/IWDjFQuT7Gs
Old 04-21-2022, 09:40 PM   #32
chewychevy67
Well tonight I split 2 of my t3 bulbs. 1 high and 1 low beam. Here are some pictures. I am waiting for my h4 housings to come in and I will do more then. I am just doing this for experimental purposes. I understand this is illegal and I would not use these if the beam pattern is harmful to oncoming traffic (which I will try to test with a few different bulbs
Old 04-21-2022, 10:30 PM   #33
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Good to see an update.... and with successful lens removals! As to legality, IF glare is not an issue, I wouldn't worry about it. Technically, some E-code conversions are not DOT-approved, but properly adjusted they don't raise any eyebrows. I have run them in various vehicles, in several states, since the early Seventies and have never had an issue.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-21-2022, 10:47 PM   #34
Getter-Done
Cool
Great Progress.
I passed a J E E P that had lights that was not legal yesterday.
I want to find my Q-Beam for Tomorow morning.
84 Chevy K-20
Old 04-27-2022, 10:52 AM   #35
Stephen717
Stephen717's Avatar
So I have to wonder how these lenses would look on Holley's new retro bright LEDs, I know it's a dumb idea but it makes a fella wonder
Stephen717 is offline   Reply With Quote
Old 05-04-2022, 06:08 PM   #36
chewychevy67
Here are brights and dims with the hella h4 glass. 1st with the morimoto 3.0 headlights and second with the hella bulbs thar came with the lenses
Old 05-04-2022, 06:13 PM   #37
chewychevy67
And the results with the t3 lens on the h4 back. 1st with morimoto 3.0 and second with the hella bulbs. Bulb is about 8 feet from my garage doors and this is only 1 single bulb. All are low beam picture first
Old 05-04-2022, 06:15 PM   #38
'68OrangeSunshine
'68OrangeSunshine's Avatar
Do you have to glue [or epoxy] the lens back on? Or does the stainless steel retaining ring hold it together?
Old 05-04-2022, 06:24 PM   #39
chewychevy67
This is what I used
Old 05-04-2022, 06:35 PM   #40
'68OrangeSunshine
That'll work.
Old 05-05-2022, 12:17 AM   #41
chewychevy67
Night shots. the cut off line actually isnt too bad with these morimoto 3.0 bulbs. This is only 1 bulb . On a vehicle it would be easier to aim. Low beam is the st picture
Old 05-05-2022, 02:39 AM   #42
'68OrangeSunshine
Is that snow, or sand, or black asphalt but looks white bc the light's so bright?
Old 05-05-2022, 10:15 AM   #43
chewychevy67
It's just dry dirt from my back alley.
Old 05-05-2022, 10:19 AM   #44
72c20customcamper
72c20customcamper's Avatar
This pic creeps me out . Looks like a skull
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-05-2022, 03:45 PM   #45
KQQL IT
At the body shop.
KQQL IT's Avatar
My old cibie lights fell apart.
Put hella h4 in their place.
Pretty neat taking a T3 apart and replacing with a H4
KQQL IT is online now   Reply With Quote
Old 05-15-2022, 12:05 AM   #46
chewychevy67
I did a tweek to the piece that blocks the light on the led light and it got rid of that line on on the low beam and I'm extremely happy about that. And I did a comparison to the original t3 an the pattern is very close to the same as I expected. Here is a picture of the bulbs in the same spot on low beam. 1st is original bulb. The led is much brighter and wider pattern.
Old 10-02-2022, 10:32 PM   #47
chewychevy67
In case anyone ever needs this info here this is what all 4 look like in the rad support. They look A little better in real life than the pictures show
Old 10-03-2022, 01:15 AM   #48
'68OrangeSunshine
Four Eyes rules the night.
