Old 02-03-2021, 12:11 PM   #7
dsraven
Re: Window seals?
adjust doors to fit the opening with no latch, so the door sits properly in the opening and the latch isn't being used to bring the door into it's final fitting spot. then install the latch and adjust that so the door fits the sheet metal height around it properly, then install the weather strip. if the weather strip doesn't let the door close it isn't a door problem, it is a weather strip problem. I had the same issue as my56 when I was helping a buddy redo his 54. the generic weather strip he bought was so stiff the door wouldn't close unless you slammed it hard and then it distorted the door kinda. he got some soffseal and it closed like it was supposed to and sealed properly. some will say you gotta leave the door closed for a week or so in the heat if possible and that will help the rubber set. I say, if it doesn't fit then it just doesn't fit. no use to strain the door and hinges etc because the weather stripping won't conform.
just my 2 cents.
dsraven is online now   Reply With Quote
