Old 07-10-2004, 02:34 PM   #1
Cliff
Heat on in summer = no good !
I have a 1972 Chevy 1/2 ton pickup, 350/700r4 with a 4 core rad and with my fan for the heat off i am still getting a flow of warm air into my cab through the vents. Is there a way I can shut off the heat, by means of not allowing water into the heater core for the summer months without hurting the engine or anything. I am running at a cool 130 degrees but am sweating due to the heat in my cab. thanks everyone. CLIFF
1972 Custom deluxe 305/350 C/10 8-foot bed with 1/4 inch diamond plate steel bed floor.
Cliff is offline   Reply With Quote
Old 07-10-2004, 02:48 PM   #2
mtdave2
newly minted old timer
mtdave2's Avatar
just go to the hardware store and get a valve, like the water spicket on you home. they make one that is straight it works better. just cut the line comming from the engine to the heater core. works great
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
Old 07-10-2004, 04:03 PM   #3
neonlarry
neonlarry's Avatar
Do you have A/C, reason I'm asking is A/C trucks have a vacuum operated valve on the heater plumbing.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 07-10-2004, 04:20 PM   #4
Cliff
yes i do have AC. however i put a valve inline and it worked WONDERFUL no more hot air cooking me at redlights and such. my AC is not hooked up. thank you guys, and gals. for the help
Cliff
