Old 02-21-2021, 10:59 PM   #2351
rustytruck50
rustytruck50's Avatar
Re: How to: Ruin a perfectly good C10
Bed floor looks great, Chris!
Hard to believe its the same truck that had the OBS sports side bed
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 02-22-2021, 07:24 AM   #2352
regan wilson
regan wilson's Avatar
Ha ha. I looked back at the first page. I forgot it was a Wrong Bed when you got it. The bed is looking good.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 02-22-2021, 04:41 PM   #2353
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by SCOTI View Post
Looks very clean & simple. Your efforts show....
You make this stuff look easy.
Originally Posted by 65StreetCruiser View Post
Looks very nice, Chris. Gonna be beautiful when you are done.
Thanks everyone! Running outta time here, and so close to the “finish line”.
Originally Posted by cj847 View Post
Where did you get the inner wheel tubs? Or did you make them? Thanks.
They came from Josh Hart of https://hart-fab.com/. Custom, one of a kind deal, but I’m sure he’d be happy to make more. I gave him my dimensions and what I wanted them to look like and a bunch of money and this is what he sent me. Super happy with them.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 02-22-2021, 10:28 PM   #2354
gringoloco
A guy with a truck
gringoloco's Avatar
A little POR-15 action on the red oak tonight. The wood is getting the Mar-K ‘forever’ treatment: https://www.mar-k.com/_assets/images.../woodtest2.pdf I was planning on a flat finish for the final coat, but the glossiness of the POR has me rethinking that maybe for a satin
-Chris
Old 02-23-2021, 10:20 AM   #2355
SCOTI
SCOTI's Avatar
I plan to do the same & hoping for a Satin finish.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-28-2021, 05:30 PM   #2356
gringoloco
A guy with a truck
gringoloco's Avatar
Good plan. Behr satin exterior is looking pretty good
-Chris
Old 02-28-2021, 05:46 PM   #2357
smbrouss70
smbrouss70's Avatar
Looks good, and it should last forever.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 02-28-2021, 09:48 PM   #2358
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks, though it might not have to last forever. Would it surprise you if I said that the whole time I’m putting this wood floor together that I can’t stop thinking about how I want to do a metal floor...
Used my square drill bit to poke holes in the flanges of the tubs. I’m liking how this is turning out; now time to get some color on them
-Chris
Old 02-28-2021, 11:51 PM   #2359
Kronald_70GMC
Kronald_70GMC's Avatar
Looks great. What exactly does a square drill bit look like?
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
Kronald_70GMC is offline   Reply With Quote
Old 03-01-2021, 07:32 AM   #2360
regan wilson
That looks awesome.
Old 03-01-2021, 07:42 AM   #2361
darkhorse970
darkhorse970's Avatar
Very nice! That’s the route I’m planning to finish my bedwood. I love this look!
darkhorse970 is offline   Reply With Quote
Old 03-01-2021, 07:34 PM   #2362
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! It looks a lot like a normal bit with a whole lot more work behind it For these, I center-punched, drilled a pilot, then step-bitted them up to 5/16” (the diameter of the stainless carriage bolts I’m using). I then used 4 pieces of painters tape to ‘draw’ a square touching the edges of the hole, a fine toothed jigsaw blade to rough out the corners, then a triangle file by hand to finish fit the square holes to the bolt heads. PITA, but I’m too cheap to buy the correct $200 punch for 14 holes...
That looks awesome.
Thanks! I’m liking it, too
Thanks Keith, it does look good. All black with just enough stainless bolt heads to break it up a bit. I’m not sure on the durability of the Behr paint though. I’m thinking a 2-part polyurethane hot rod black would probably be better, but who am I to argue with Mar-K’s test results
-Chris
Old 03-01-2021, 08:20 PM   #2363
SCOTI
SCOTI's Avatar
Exactly.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-01-2021, 09:48 PM   #2364
smbrouss70
smbrouss70's Avatar
Not at all! I'd actually be disappointed if you weren't thinking about the next version of modifications...
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 03-02-2021, 07:02 AM   #2365
regan wilson
Since you like working so much I have an idea. Take an old tailgate and section up the inside of it. Then cut yours up and build your tailgate so the factory lines aren't cut in half by the raised bed floor. Hey you are the one doing all the work and we like to watch. Lol
Old 03-02-2021, 11:06 PM   #2366
gringoloco
A guy with a truck
gringoloco's Avatar
It’s like you’re in my brain. I actually have the gate leaning against the wall. Planned to use it for that as well as using the lettering on the rear of the raised floor. Won’t happen right now as I’m running out of time and need to focus on more pressing things, but sometime in the future, maybe? It’s all built in my head...
-Chris
Old 03-02-2021, 11:43 PM   #2367
fishingjred73
fishingjred73's Avatar
WOW that bed floor looks GREAT!!
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 03-03-2021, 06:50 AM   #2368
regan wilson
Now that's funny. Bad thing is if this was 20 years ago I would have the piece to give you.
Old 03-04-2021, 12:00 AM   #2369
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks James! Looks better in pictures than in person, but it’s just a nice driver
While the rear tubs are off getting powder-primed, I started goofing with the hvac. Didn’t get far other than pulling the unit and enlarging the firewall holes for these billet trim rings. I’m not in love with them, but they’re definitely better than plain sheetmetal holes. Thinking of painting them my favorite shade of VHT...
-Chris
Old 03-04-2021, 12:30 AM   #2370
SCOTI
SCOTI's Avatar
Scot approved 😎
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-04-2021, 12:35 PM   #2371
smbrouss70
smbrouss70's Avatar
thinking of painting them my favorite shade of vht...
YES!
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 03-04-2021, 04:09 PM   #2372
fatbass
fatbass's Avatar
You're doing amazing things with that truck, Chris. I'm in awe. Please never finish it.
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 03-04-2021, 08:04 PM   #2373
gringoloco
A guy with a truck
gringoloco's Avatar
Scot approved 😎
YES!
Ok, twist my arm
That’s a heckuva compliment, thanks. I tell my wife I’m building my coffin; that will probably be when I stop ruining it...
-Chris
Old 03-05-2021, 12:10 AM   #2374
gringoloco
A guy with a truck
gringoloco's Avatar
Well, the ac unit is back in with the bezels in place. Don’t look too close though, because the paint bubbled and cracked around them... Oh well, I don’t have time to tear the whole business apart and repaint the firewall, so on to the next thing. Hopefully getting the wheel tub in place will make it not so obvious.
-Chris
Old 03-05-2021, 12:13 PM   #2375
smbrouss70
smbrouss70's Avatar
The picture is dark, we can't see anything bad. Besides, I know a guy.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
