#26 |
Re: Frame paint or powder coat
Sand blasted and Kirker epoxy primer. Easy to touch up.
#27 |
![]() Join Date: Jun 2019
Ok thank you
#28 |
![]() Join Date: Mar 2019
#29 |
I used a simple HVLP gun from Harbor freight.
#30 |
![]() Join Date: Dec 2013
I used Tractor supply Oil based Enamel Tractor paint with the catalyst hardener and thinned it to shoot thru a cheap harbor freight gun for less than $100.00 . Apply over primer or direct to metal . It works great also can be touched up with a spray can . it's tough stuff when dried .
![]() https://www.tractorsupply.com/tsc/pr...l?cm_vc=-10005 https://www.tractorsupply.com/tsc/pr...t?cm_vc=-10005 https://www.tractorsupply.com/tsc/pr...t?cm_vc=-10005 https://www.tractorsupply.com/tsc/pr...k?cm_vc=-10005
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#31 |
Ttt
#32 |
All about them K’s
![]() Join Date: Jun 2014
I used satin chassis saver on my K20. Wire wheeled the whole frame, cleaned it up with prep solv, and then brushed the chassis saver on. It’s not as clean looking as being sprayed but, reading online the consensus was that brushed was more durable than sprayed. I would/will definitely use it again. Brakekleen doesn’t phase it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#33 |
As for what I used to apply the paint. For the POR15 I used disposable brushes from Harbor Freight. I allowed me to work the POR into the areas that are hard to spray. For the top coat just a cheap spray gun from Harbor Freight
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
