Old 03-15-2021, 05:56 PM   #1
eric8
Z bar removal
Can someone tell me what I'm missing? How does the z bar release from the bellhousing?
eric8 is offline   Reply With Quote
Old 03-15-2021, 06:18 PM   #2
Southcity
Southcity's Avatar
Re: Z bar removal
If I recall correctly, there should be a depression (flat side) on each side of the ball-stud which allows you to get an open end wrench on it to screw it out/in to the housing. You might need to degrease/clean the area to get a better look at what you are working with. If you are removing/re-installing, I highly recommend replacing all the "wear" parts (studs, seals, clips etc).
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 03-17-2021, 09:47 PM   #3
v30crewcab
v30crewcab's Avatar
Re: Z bar removal
loosen the bolt on the frame side, and it should move up, and out of the bracket. then you can pull it off the bellhousing knob.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
