Front brake hose question
So I installed a CPP front disc brake conversion on my 70 C10. The brakes work great and have no real issue except the hoses from the frame to the caliper are way too long and the orientation of how the attach to the caliper makes them rub. I cut a piece of rubber hose to put over the brake hoses for not to keep chafing to a minimum but is there a different or maybe shorter brake hose people use? I would prefer my hoses to not touch anything if possible.
![]() Join Date: Feb 2010
Re: Front brake hose question
I'm rehabbing a 70 now with disc brakes. The hose i used was from Autozone 88466 seems to fit good. You will have to file the frame mount where the metal line meets the hose.
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
![]() Join Date: Dec 2013
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Awesome! Just picked up a set of the 88466 hoses and will install when I get time. Look to be about 3 inches shorter than what I have now.
![]() Join Date: Jun 2005
I used these as well, they fit nicely
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#7 | |
Who Changed This?
![]() Join Date: Jan 2013
Disclaimer- when I put the disc brake conversion kit on my '70, I had to find different hoses, as the kit did not include them. I ended up getting '73 hoses and took the center clip off because I was too lazy to run the steel lines like would be "proper". Back to keeping an eye on the hoses. They obviously don't bend a lot, but they may rub, as has been mentioned. If I see that, I'll work on it, but so far they look fine.
![]() Join Date: Aug 2019
You can bet that GM wouldn't have paid to put a metal bracket on that hose if it wasn't needed.
Who Changed This?
Yup, they were routed differently on '73 and up.
