Old 05-23-2021, 07:59 AM   #1
03BlkZ
Front brake hose question
So I installed a CPP front disc brake conversion on my 70 C10. The brakes work great and have no real issue except the hoses from the frame to the caliper are way too long and the orientation of how the attach to the caliper makes them rub. I cut a piece of rubber hose to put over the brake hoses for not to keep chafing to a minimum but is there a different or maybe shorter brake hose people use? I would prefer my hoses to not touch anything if possible.
03BlkZ is offline   Reply With Quote
Old 05-23-2021, 09:28 AM   #2
OL SKOOL
OL SKOOL's Avatar
Re: Front brake hose question
I'm rehabbing a 70 now with disc brakes. The hose i used was from Autozone 88466 seems to fit good. You will have to file the frame mount where the metal line meets the hose.
OL SKOOL is offline   Reply With Quote
Old 05-23-2021, 09:40 AM   #3
leddzepp
Moderator
leddzepp's Avatar
Here you go:
http://67-72chevytrucks.com/vboard/s...d.php?t=738254
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-23-2021, 09:57 AM   #4
Grumpy old man
Grumpy old man's Avatar
Here are some more pictures/ info .
http://67-72chevytrucks.com/vboard/s...d.php?t=818077
Old 05-23-2021, 03:25 PM   #5
03BlkZ
Awesome! Just picked up a set of the 88466 hoses and will install when I get time. Look to be about 3 inches shorter than what I have now.
Old 05-23-2021, 03:32 PM   #6
70STOVEBOLT
70STOVEBOLT's Avatar
I used these as well, they fit nicely
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-23-2021, 09:56 PM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
I'm going to say keep an eye on those hoses, because that looks like a lot of bend (kind of tight).
Disclaimer- when I put the disc brake conversion kit on my '70, I had to find different hoses, as the kit did not include them. I ended up getting '73 hoses and took the center clip off because I was too lazy to run the steel lines like would be "proper". Back to keeping an eye on the hoses. They obviously don't bend a lot, but they may rub, as has been mentioned. If I see that, I'll work on it, but so far they look fine.
~Steven
Simi Valley, CA
Old 05-24-2021, 07:54 AM   #8
BigBird05
You can bet that GM wouldn't have paid to put a metal bracket on that hose if it wasn't needed.
BigBird05 is offline   Reply With Quote
Old 05-24-2021, 10:10 AM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yup, they were routed differently on '73 and up.
~Steven
Simi Valley, CA
