#11 | |
Re: Make it handle
My thinking is that the Durango is a considerably heavier vehicle with a 5x5 bolt pattern by default. Could easily sub in Jeep Wrangler hubs which would have the same BP, be very common place, and have certainly been proven to withstand abuse. While the Vette is good for racing a 3300 lb car, I'm not sure it is the best for a 4,000 lb C10 and it requires custom bolt pattern to be drilled. My thinking on the steering arm is the same for sure. I know that taller upper ball joints were discussed earlier in the threads with good results so I was after a similar after. While it is taller for 60s GM, these spindles are super short compared to a modern truck spindle. The modern ball joint arrangement may be a good option. I see so many new cars where the upper ball joint is basically on top of the tire! I agree on the forging being a better option for long life. It just seems cost prohibitive unless large orders. Wondering out loud if a billet aluminum machined spindle could be designed for sufficient strength and life. I know DSE'S new upright is forged but not sure about Wilwood Pro Spindle. My biggest complaint with aftermarket options currently available is lack of a spindle with bolt on arm for tuning and also lack of "off the shelf" bolt on sealed hub in 5x5 bolt pattern. There has to be a way to incorporate those features and I figured that I may as well improve other geometry at the same time if possible. Last edited by cjohnson6772; 08-22-2021 at 05:10 PM. |
| Bookmarks |
