Old 09-14-2021, 12:04 PM   #1
old51sedan
old51sedan's Avatar
Grille assembly
I'm trying to assemble my inner and outer grille for my 69. It's been a while and I guess I should have taken pictures. I will post a picture of what I thought was a grille assembly kit that I bought a while back, hopefully someone can tell me if this is suppose to work.
old51sedan is online now   Reply With Quote
Old 09-14-2021, 12:57 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Grille assembly
https://www.classicparts.com/1969-72...nfo/61%2D953/#
white plastic clip with screw , Push into hole and tighten screw to expand
The metal clip is used on gm cars to install windshield/ rear window trim mouldings .
https://www.clipsandfasteners.com/Wi...SABEgI3a_D_BwE
Old 09-14-2021, 10:22 PM   #3
ho70
ho70's Avatar
Re: Grille assembly
brothers trucks on YouTube has a great video on how to use pliers with a nut taped to push those white clips in.
ho70 is offline   Reply With Quote
Old 09-15-2021, 06:19 AM   #4
Grumpy old man
Re: Grille assembly
Install video .
https://www.youtube.com/watch?v=15LUCtb3KKU
Old 09-15-2021, 09:02 AM   #5
old51sedan
old51sedan's Avatar
Re: Grille assembly
Originally Posted by Grumpy old man View Post
Thanks guys for the information and the link to the video. The only problem I see is that my grille does not have the square holes in it for the clips, they are all round (I'm reusing my original grille) so it looks like I may have to use the original style clips and screws. I don't know if a person could grind the edges of the white clips to make them round or not.
Old 09-15-2021, 10:17 AM   #6
Grumpy old man
Re: Grille assembly
Do you have any pictures of what your working with ? grille/ clips /screws ?
Old 09-15-2021, 05:09 PM   #7
old51sedan
old51sedan's Avatar
Re: Grille assembly
Grumpy, On the first page is the screw and clip, here is a picture of my 69 grille, round holes (I have 3 grilles all alike) also a shot to inner grille with square holes. Were all the originals made with round holes and repo's made with square holes?
Old 09-15-2021, 07:17 PM   #8
Grumpy old man
Re: Grille assembly
In this instance I do believe they intended for a square clip to fit in a round hole . I gave a grille the same as yours to my neighbor he has it on his garage wall , I'll get some pictures of it tomorrow . I'm pretty sure your going to have to take the corners off your square clips to fit tightly into the round holes of the grille and then tighten the screws to expand the clips .
Old 09-15-2021, 07:39 PM   #9
Davidf
Re: Grille assembly
Why not just turn the round holes into rectangular holes
Davidf is offline   Reply With Quote
Old 09-16-2021, 03:47 PM   #10
fun in dirt
fun in dirt's Avatar
Re: Grille assembly
ZIP TIES are your friend ... laughing, not laughing
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 09-20-2021, 07:50 PM   #11
old51sedan
old51sedan's Avatar
Re: Grille assembly
I solved the problem, found out it was easier to cut the tips off the back side, grind it smooth on the back side, put it in the grill use the screw thru it into one of the old style c clips. It tightens up nice and looks good.
Old 09-21-2021, 11:40 PM   #12
cericd
cericd's Avatar
Re: Grille assembly
Good info.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
