09-14-2021, 12:04 PM | #1 |
Grille assembly
I'm trying to assemble my inner and outer grille for my 69. It's been a while and I guess I should have taken pictures. I will post a picture of what I thought was a grille assembly kit that I bought a while back, hopefully someone can tell me if this is suppose to work.
09-14-2021, 12:57 PM | #2 |
Re: Grille assembly
https://www.classicparts.com/1969-72...nfo/61%2D953/#
white plastic clip with screw , Push into hole and tighten screw to expand The metal clip is used on gm cars to install windshield/ rear window trim mouldings . https://www.clipsandfasteners.com/Wi...SABEgI3a_D_BwE
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-14-2021, 10:22 PM | #3 |
Re: Grille assembly
brothers trucks on YouTube has a great video on how to use pliers with a nut taped to push those white clips in.
09-15-2021, 06:19 AM | #4 |
Re: Grille assembly
09-15-2021, 09:02 AM | #5 | |
Re: Grille assembly
09-15-2021, 10:17 AM | #6 |
Re: Grille assembly
Do you have any pictures of what your working with ? grille/ clips /screws ?
09-15-2021, 05:09 PM | #7 |
Re: Grille assembly
Grumpy, On the first page is the screw and clip, here is a picture of my 69 grille, round holes (I have 3 grilles all alike) also a shot to inner grille with square holes. Were all the originals made with round holes and repo's made with square holes?
09-15-2021, 07:17 PM | #8 |
Re: Grille assembly
In this instance I do believe they intended for a square clip to fit in a round hole . I gave a grille the same as yours to my neighbor he has it on his garage wall , I'll get some pictures of it tomorrow . I'm pretty sure your going to have to take the corners off your square clips to fit tightly into the round holes of the grille and then tighten the screws to expand the clips .
09-15-2021, 07:39 PM | #9 |
Re: Grille assembly
Why not just turn the round holes into rectangular holes
09-16-2021, 03:47 PM | #10 |
Re: Grille assembly
ZIP TIES are your friend ... laughing, not laughing
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
09-20-2021, 07:50 PM | #11 | |
Re: Grille assembly
09-21-2021, 11:40 PM | #12 |
Re: Grille assembly
Good info.
