#176 |
Re: '67-'72 Power Brake Booster Bracket With Hydraulic Clutch Conversion
GM CaptainFab. I hope all is well. I would like order your Hydraulic clutch kit for my LY6/TR6060 swap. I’m interested in the flat clutch bracket. I’ll wait for your pm. Thanks in advance, clark.
#177 |
60-66 Nut
Pm sent. I forgot to ask what year your truck is. The '67-'68 are different than the '69-'72's
#178 |
Hello captainfab. Do you have the flat plate so that I sandwich between the current brake booster and firewall? If I would rather keep my current brake booster bracket as I have Running, driving truck. My booster bracket is totally different Than the one you sent. Thanks in advance, clark.
#179 | |
60-66 Nut
Did you tell me that you wanted just the base plate with no booster mounts? Does your current booster not bolt up to my booster bracket? Do you want to return the booster bracket? How long ago did you order? What is your name?
#180 |
Hello captainfab. I requested the flat piece. My name is Derrick Clark. Look at post #176 and #178. I didn’t say base plate. I used the wrong terminology. Excuse for me that. I am willing to pay for it. I want what’s easier for me. Send me an invoice. Thanks in advance , clark.
#181 |
60-66 Nut
I sent you a PM.
#182 |
Hello 67-72 board members. I wanna take this to commend captainfab for his craftsmanship of the brake booster bracket with hydraulic clutch kit. He’s very knowledgeable of his product. Me being a novice, truck builder I thought I needed a flat clutch bracket. I didn’t take the time necessary to look at the kit and components. I was stuck at my own way of installing the kit. The I bought this kit from captainfab and it is awesome. It works as stated if you follow the directions. It even has pictures. At my request he sent the flat bracket, which I will stay in a box, unused. Captainfab thanks
#183 |
60-66 Nut
Thanks for the kind words and the installed pic. So it looks like you did not really need the flat plate after all?
#184 | |
Posted via Mobile Device |
#185 |
Can you set me up with an uncoated manual brake setup? And do you have clutch slaves available as well? Or recommendations on which one to go with? 70 C10 SBC with a TEX T101 (T10 based).
#186 |
60-66 Nut
PM sent. No I do not do anything with clutch slave cylinders. I supply the proper clutch master for the slave cylinder/hydraulic release bearing being used.
#187 |
60-66 Nut
Due to an increase in the cost of having my parts laser cut, I have been forced to raise my prices. I'm not making any more money, just trying to stay in business with these increases in my costs. Thanks for understanding.
#188 |
I have a 1967 k10, i need just the flat plate and inside cab parts, i already have a clutch master and a hydro-boost set up
Thanks |
#189 |
60-66 Nut
I sent you a PM with ordering and payment info.
#190 |
Captainfab-----pm sent did you get it ?
#191 |
60-66 Nut
Yes I did and I just sent you a reply. Sorry but with the high number of orders I have on a continuous basis, I just can not be here on this forum everyday like I used to for many years. For a faster reply please send me an email to captainfab454@hotmail.com as stated in post #1.
#192 |
Hey capt. Received my kit today. Fast shipping. Thanks.
I received a different interior mount than I have seen in the pictures. Just wanted to make sure it’s correct… I will work on my mock up this week and post some new pictures if so. Thanks again |
#193 |
60-66 Nut
Yes I do send the correct parts as needed for the kit you requested. Some of the installation pics are from 10+ years ago of a previous design. With working 80hrs/7 days a week every week every month, I simply do not have time to completely mock up another installation to take a bunch of pics. I wish I had the time to write up proper installation instructions for all 26 of my products, but I do not.
#194 |
I am interested in a flat plate kit as I already have your booster bracket. What would be the cost for that?
Thanks |
#195 |
60-66 Nut
Deleting the booster mounts reduces the cost by $25.00. So without any clutch master upgrades, you are looking at $225.00 plus $22.65 for shipping.
#196 |
![]() Join Date: Nov 2020
Hello,
I would like to buy your clutch kit for 69 C30. The wilwood master cyl I could buy myself if you gave me the specs. If you need pics let me know. Thanks Ken inskeep1951@cablemo.net
1990 Toyota 4Runner Mercedes swap 2004 Chrysler Crossfire (Saved from 6 years in weeds) 2004 Chevy Silverado (CA truck no rust) 2000 Dodge Intrepid 400,000 Miles 1969 Chevy C30 work in progress (Saved from pasture) |
#197 |
60-66 Nut
Email replied to and payment received. Thanks
#198 |
Payment and email with order info sent
#199 |
Andy
Captainfab, I'm interested in one of these kits for my truck. I have a 1969, but have converted it to power disc brakes. I measured the booster last night and it appears to be about 10.75-11" in diameter. I've also attached a few pictures for reference. Will your kit work? Do you need me to check anything else to verify fitment?
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi 1969 CST/10 383|Aisin AR5 5 speed 1972 K5 LT1|Turbo 350 4x4 2005 Duramax 2500HD 4x4 |
#200 |
This is how mine turned out. Had to cut off those pretty parts.
I asked if he wanted picture but he said he knew all about these trucks. It worked out in the end this was a 69 C30. Ken
| Bookmarks |
